Cpvc!? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2010, 10:39 PM   #1
Owner
LateralConcepts's Avatar
Cpvc!?
Wondering - Unless the Authority having jurisdiction says he/she want's to see it, why would anyone use CPVC over PEX?
In my opinion CPVC is garbage. Might as well use PB. PEX is far superior.
LateralConcepts is offline   Reply With Quote
Old 06-22-2010, 05:33 AM   #2
the Musigician
DangerMouse's Avatar
Hmmm, let me think.... pex cost? pex tool cost? pex connector cost?
All GREAT reasons for me!
cpvc works fine and costs way less than pex and needs no special crimper tools....
A saw and two cans of primer and glue is all that's needed!
Everyone's entitled to their opinions though!
DM
Old 06-22-2010, 08:22 AM   #3
It works. That is all that matters to most. I know there are new products coming out all the time, and many are quality products. I really hate to see the "plumb" taken out of Plumbing. Looking at Pex runs reminds me of how much I like spaghetti.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-22-2010, 08:37 AM   #4
Owner
I guess I may have a different opinion if I were to live in a different climate. In Idaho we have hot summers and cold winters. The expansion, contraction, freezing, kills pipe. Don't get me wrong, I don't care to see the "Plumb taken out of plumbing" either. I've seen PVC and CPVC however, become so brittle you could crush it in your hand after just a few years. Rarely in my service past did I see PEX burst in freezing weather and don't recall ever seeing it become brittle. Likewise, I've seen major disasters with copper, PVC, CPVC, and Quest (PB). Certainly plastic pipe with glue fittings is simpler for the DIY'er without specialized tools.
Old 06-22-2010, 09:03 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I love using CPVC........
For T&P drains...
Journeyman Plumber
Old 06-22-2010, 09:22 AM   #6
Owner
Haha I don't think that's legal though is it? I see it all the time done with pex or pvc, but should be copper I think within 18"
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
Old 06-22-2010, 09:44 AM   #7
Owner
Ok, I just looked it up and you're in the clear. According to IAPMO/ANSI 2003 UPC (608.5) Relief valves located inside a building shall be provided with a drain, not smaller than the relief valve outlet, of galvanized steel, hard-drawn copper piping and fittings, CPVC, or listed relief valve drain tube with fittings which will not reduce the internal bore of the pipe or tubing.
Lateral
(208) 818-8241
help pvc & cpvc or metal pipe? ok_cntrygrl7 Plumbing 0 05-11-2010 02:18 PM
Confused about Pex tubing and cpvc staceythalmann Plumbing 3 05-28-2009 07:19 PM
cpvc advice on roughing in my house jimmy21 Plumbing 8 07-25-2008 07:38 PM
burying CPVC under concrete amakarevic Plumbing 17 03-25-2008 08:45 AM
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve andy Plumbing 6 12-12-2006 09:02 PM
