Cover/remove A Plumbing Rough-in... - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2010, 02:28 PM   #1
Cover/remove a plumbing rough-in...
Wanna make sure others agree...
I have no need for a bathroom in my basement.
(I have only one room and I am not willing to give up the space).
Here is the pic...
http://i798.photobucket.com/albums/y...asement_01.jpg
Tub drain box - I have broken out concrete (that was uneven). I plan to clean it out a bit - put sand to cover pipes - then level off with concrete.
Toilet hole - floor leveler on this to make smooth (there is a pretty solid cap or something that has some cardboard on edges - it seem pretty solid (supported my weight when I stepped on it).
Pipe for sink drain - cap off (in fact, I have already cut it down a bit and put a cap on it to see if it would change plumbing in my house (did not / almost seems better). Will put cap on with PVC glue.
Gonna put laminate floor down in room.
Good plan?
Thanks,
JB
jbatl is offline   Reply With Quote
Old 05-05-2010, 01:15 PM   #2
In a perfect world you would normally disconnect this whole bathroom group from the main drain for proper abandonment of the piping below the slab. What you have are a bunch of dead legs on an open drainage system. This isn't a horrible thing, and as a plumbing engineer I have seen contractors do it both ways, but an inspector would have you cap off the line that feeds into the active drain line, which of course is expensive and requires additional saw cutting of the slab. If I were in your shoes and doing it myself, I would cut the pipes down to at least 4 inches below the finished floor elevation, caps off the pipes making sure they were solid and secure, then just concrete over them like you descibe and call it a day.
The Engineer is offline   Reply With Quote
what to do for plumbing rough inspection? red86yota Plumbing 5 09-12-2010 04:39 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 01:09 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 08:30 AM
rough in plumbing psiter Plumbing 5 08-23-2006 05:44 PM
