Cover For Artesian Well? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 02:47 PM   #1
Rewards Points: 14
Cover for artesian well?
I recently visited friends in the country. They have an artesian well which is about 40 years old. It is made from 36" inside diameter concrete sections, but the cover is just a thin piece of plastic. A branch fell on the cover and broke it.
We replaced it with a plastic cover in much better condition.
After doing some reseach on the web, my understanding is that a concrete cover is required to be legal. But I was not able to find one locally, closest one I found is made 300 miles away in Maine.
For those who have artesian wells, what do you use for a cover?
Thanks.
bw77 is offline   Reply With Quote
Old 11-27-2011, 03:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Build your own concrete cover.
Old 11-27-2011, 06:03 PM   #3
Lightfoot's Avatar
Rewards Points: 272
i agree. get ya some plywood and a couple o 2 x 4's and have at it. Quikrete is cheap!
Lightfoot is offline   Reply With Quote
Old 11-27-2011, 08:17 PM   #4
Msradell's Avatar
Rewards Points: 128
Great idea, don't forget to put some rebar into it to keep it from breaking apart. I would probably use #4 on about 8" centers in both directions wire tied with a cross.
Msradell is offline   Reply With Quote
Old 11-27-2011, 11:03 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
And maybe a (rebar) loop or two for lifting.
Old 11-27-2011, 11:11 PM   #6
Msradell's Avatar
Rewards Points: 128
Good point!
Old 11-28-2011, 07:06 AM   #7
Rewards Points: 14
Thanks to everyone for your ideas.
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Above ground pool cover question joeg679 General DIY Discussions 8 08-03-2010 05:41 PM
Radiator Cover Fix zetti1102 Carpentry 5 03-10-2010 11:31 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
