Of Course Something Else Had To Go Wrong - Leaking Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2006, 08:07 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Of course something else had to go wrong - leaking pipe.
About to put back my vanity, its been so long since I had removed it, I had forgotten about the bucket that was in it full of water when I took it out. Upon investigation, I discovered where the leak was coming from. The cold water supply, the 5/8 copper pipe that sticks about 1 inch out of the tile wall, just before where the shutoff valve compression nut would go, is bent. Its a little chopped up, but also a little squared - as if someone had used plyers on it. I remember the compression sleeve came off that side much easier than the other, so I'm thinking maybe someone bent the pipe to get the sleeve off? At any rate, what I'm trying to figure out is, am I going to have to remove a bunch of tiles here to try an access enough of the pipe that I can cut it back and replace a part of it?
J187 is offline   Reply With Quote
Old 07-30-2006, 08:15 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Maybe, maybe not, I can't see it from here, if you was to cut off the shutoff valve just on the back side of the compression nut, you will need a min 1/2" left out the wall, do you think you would be able to solder on a copper male adapt? If so then you could use a FIP shutoff vavle in it's place.
Ron The Plumber is offline   Reply With Quote
Old 07-30-2006, 02:17 PM   #3
J187's Avatar
Rewards Points: 516
Ok, I took a better look. No way I'm able to sweat anything onto this pipe. I am gonna have to chisel away some tile. Not a huge deal, the wall will be well hidden by the vanity anyway. Is there any particular way I should seal this up when I'm done? Thanks.
Old 07-30-2006, 02:20 PM   #4
Journeyman Plumber
Silicone
Old 07-30-2006, 04:02 PM   #5
J187's Avatar
Rewards Points: 516
it'll be like a 4" x 4" area or so..
Old 07-30-2006, 04:04 PM   #6
Journeyman Plumber
Use what eever it takes, drafts and bugs is what your trying to keep out.
Old 07-30-2006, 05:50 PM   #7
J187's Avatar
Rewards Points: 516
ok, cool. thanks. Update - By knocking out just 2 3x3 tiles, I was able to sweat in a coupling and a nice new piece of copper pipe. Luckily I have a nice little tight-space pipe cutter which I had to tie a string around in case I dropped it in the wall :D. Anyway, I am going to test it with some nice shiny new shutoff valves. Thanks for the help, I think all is well now.
Old 07-30-2006, 07:56 PM   #8
Journeyman Plumber
Good job
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 01:36 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 12:29 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Leaking Pipe STEPBK2 Plumbing 1 12-06-2004 12:57 PM
