Coupling PEX Underground? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2010, 10:50 AM   #1
coupling PEX underground?
I need to couple together some 3/4" pex underground, before coming up into my mechanical room. It's the main water supply line.
I've never plumbed with PEX before and have no PEX tools. I assume the "sharkbite" fittings are not appropriate for underground use?
Do I need to buy some special PEX tools to be able to properly deal with fittings?
I don't anticipate doing much more with PEX, and once I'm in the mechanical room it will all be copper (already is).
Thanks.
wombosi is offline   Reply With Quote
Old 10-03-2010, 11:28 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I would try to get longer lengths of pipe to eliminate any underground couplings. If you must, here is about the cheapest crimp tool you will find:
http://www.lowes.com/pd_324341-943-0...frameTransport
It is used with a pair of vise grips to provide the crimping power. Good for low volume jobs or very tight spaces. I used a pair to replumb my camper.
Coastal South Carolina
Old 10-03-2010, 03:21 PM   #3
i agree with previous post. Try to obtain longer run of pex to avoid any fittings. Even when using copper, plumbers use soft rolled no joint copper to avoid fittings.
moopey is offline   Reply With Quote
Old 10-04-2010, 11:56 AM   #4
Owner
LateralConcepts's Avatar
Thanks.
I wouldn't use PEX underground. Use 200psi Poly. You can buy it in a 100' roll. Make the transition to copper or PEX by using a brass 3/4" barbed by thread (MIP) adapter. Then an FIP adapter.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 10-04-2010, 03:08 PM   #5
guys, thanks for the advice.
unfortunately, i already have a 100' roll of PEX buried 4' down, running from house to barn. no way to redo this at this point.
options are:
1) splice underground and continue the trench, to come up vertically into the mechanical room. the vertical part will require some sort of "heat tape" as it will be in unheated space.
2) come up into the unheated space right where i am now wiht the end of the PEX sticking up a few feet, and run it along my drainage chase and into the mechanical room. this way at least the joint will be in the open, but i'll have much more of it (maybe 20') exposed to unheated space and requiring some sort of heat tape.
thanks. hope having hte PEX underground is not irreparable in terms of being able to get water through it. i did this over a year ago and people told me it was fine for this application. granted, i should have bought a longer roll of it back then. didn't realize joints were such an issue.
Old 10-08-2010, 12:03 AM   #6
Plumb or Die!
I'd use a "Mueller" corporation coupling, not a crimp coupling. It's like a compression fitting, but different.
plumber666 is offline   Reply With Quote
Old 10-08-2010, 09:00 AM   #7
Rewards Points: 152
Here's what plumber666 is talking about (H15403)
http://www.muellercompany.com/water/...t.aspx?catid=6
Nothing wrong with laying PEX in the ground, they use it here all the time with the noted compression couplings and I've never seen a problem with it.
Make sure you use a stainless steel insert/stiffener
burnt03 is offline   Reply With Quote
Old 10-08-2010, 03:48 PM   #8
Rewards Points: 1,214
I'd be afraid of splicing anything underground without knowing where it is and how deep it is. If I had your problem I would probably dig a deep hole and install a sonotube or a box where the splice is so I could look in and check it once in a while or if there is a leak somewhere that would be the first place I would look.
COLDIRON is offline   Reply With Quote
Specialty bolt - Lag bolt with attached coupling nut? 5thumbs Building & Construction 6 08-22-2011 02:08 PM
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 11:31 AM
Underground Wiring From House to Garage Virginhomeowner Electrical 7 05-21-2010 11:53 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
