Counter Top - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2005, 03:20 PM   #1
Counter top
What are counter tops held to the vanity with ? For example, how does a marble or granite top adhere to a bathroom vanity ? TIA
Scott_K is offline   Reply With Quote
Old 03-28-2005, 05:37 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sinks and countertops are often just held to the top framing of vanity or cabinet bases with dollops of caulk around the perimeter.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-28-2005, 05:59 PM   #3
Contractor
I use clear silicone sealer, not that I think that it makes that much difference. The weight pretty much holds it in place, bubble gum would probably keep it from sliding. I've seen guys use double sided tape too, make certain that you are on your marks when you set it down.
Teetorbilt is offline   Reply With Quote
Old 03-29-2005, 10:49 AM   #4
Thanx for the feedback.
If it's off the mark and set it down, what happens ? I thought I'd have a few seconds before it really sets in.
Old 03-29-2005, 12:23 PM   #5
Contractor
I was refering to the double sided tape. Any of the others will give you some wiggle time.
Old 03-29-2005, 12:52 PM   #6
Oh ok, Thanx Again !
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 06:18 PM
Need Counter Help Fast! skits Carpentry 9 07-29-2007 01:19 AM
Pass-thru counter gshock Carpentry 6 07-28-2007 11:44 PM
counter tops feb Remodeling 3 09-02-2005 11:56 PM
