Could Electrolysis Have Damaged Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2011, 10:26 PM   #1
Rewards Points: 682
Could electrolysis have damaged water heater?
I replaced a water heater that was leaking. I've never had a w/h tank leak before.
It seems we had an electrolysis problem. The copper water lines to the w/h were directly attached to galvanized nipple and brass valve respectively, and had balls of corrosion growing on them the size of tennis balls.
Can this also damage the walls of the tank?
darsunt is offline   Reply With Quote
Old 09-05-2011, 02:23 AM   #2
Rewards Points: 6,652
You answered your own question.
Old 09-05-2011, 07:56 AM   #3
Civil Engineer
Rewards Points: 4,700
I had a similar problem about 10 years ago. I replaced a water heater tank and did not use dielectric unions. Within two years the fittings were so badly corroded the tank leaked, and could not be salvaged. My bad, I should have used the proper fittings. As to damaging the interior of the tank, I have no idea what mine looked like, however it was irrelevant since the threaded fittings were so badly corroded I could not get a seal.
Daniel Holzman is online now   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
