#1 |
cost : tankless vs traditional hot water heater
Sharing my recent experience. We had a 75 gal gas fired hot water heater leak. Went to store with intention of replacing it with new tankless system. Cost of tankless including equipment and install from $3800 to $4300 (got 4 difference quotes). And federal rebate calculation which has a very convoluted calculation was only $700. TOTAL Cost for traditional (installation and equipment) = $1200 . Man it makes doing the right thing impossible these days.
#2 |
Xtreme DIY'r
I'm installing solar for HW, it won't work year round for me w/older panels
Right now I have (1) 4x12' panel heating my hot tub ~450g of water to 108 Output is around 124 degrees at times I have some more panels that I will connect to heat water for the house So far with 6 panels I have spent ~$300 My electric bill last month was $100 less then it used to be |
#3 |
From the posts on other forums your savings with a tankless are not as high as the salesmen tell you. If you have a regular gas water heater (not power vent) you will still have hot water if the power goes out, with a tankless you are SOL!
| Tags |
gas water heater, leaking water heater, tankless, water heaters ![]() |
| Display Modes | |
| DIY gas tankless water heater | lofar | Plumbing | 42 | 12-19-2010 02:01 PM |
| Tankless Water Heater | welshie | Plumbing | 12 | 03-03-2010 01:46 PM |
| Tankless water heater | brewmastr | Plumbing | 2 | 01-11-2010 10:35 AM |
| 77amp Tankless Water Heater on 150amp House??? | deeze | Electrical | 29 | 08-18-2009 01:37 PM |
| Tankless water heater proper pipe size? | gante | Plumbing | 5 | 04-06-2009 03:28 PM |
