Old 01-13-2011, 11:59 AM   #1
cost - leak on main water line and changing valve
I have a small leak on my main water line going to the meter in front of my house....what cost should I expect for fixing that?
Also, the plumber indicated that it would be better to have a ball valve instead of a gate valve for the main water valve to the house, but he wants $375 to change it which seems way too high.
What should I expect as a cost?
Thanks!!!
sandrashand is offline   Reply With Quote
Old 01-13-2011, 12:08 PM   #2
Where are you? How long is the run of pipe? Is he going to just repair the leak or replace the whole pipe? What material is the existing pipe? How deep is the existing water service?
broox is offline   Reply With Quote
Old 01-13-2011, 12:15 PM   #3
Experienced
Jackofall1's Avatar
I would be careful using a ball valve, if not exercised regularly, ball valves, especially lower end ones, will seize, I believe this is why gate valves are used, they are almost indestructable.
Old 01-13-2011, 12:16 PM   #4
You are right, that price is way out of line. I suggest you hire someone from Craig's list.
fireguy is offline   Reply With Quote
The Following User Says Thank You to fireguy For This Useful Post:
sandrashand (01-13-2011)
Old 01-13-2011, 12:25 PM   #5
I am in Houston, texas and he is going to replace a small section with pvc piping...he wanted to change the valve going to the water meter, but I read online that usually the city is responsible for both valves on either side of the meter....he wanted $569
As for the valve on the main water line at the house, he would just change the valve from gate to ball...for this he wanted 375$
Old 01-13-2011, 12:55 PM   #6
Owner
LateralConcepts's Avatar
No offense, but I think you're backwards on your thinking. Ball valves have far fewer problems, leaks, etc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
plumberinlaw (01-13-2011)
Old 01-13-2011, 01:03 PM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,... That's been my experince too....
I pretty much use nothing but ball-valves anymore...
Old 01-13-2011, 01:09 PM   #8
Experienced
Jackofall1's Avatar
None taken, but I have seen process ball valves especially inexpensive ones freeze up because of lack of use, where a gate valve can usually be persuaded to move.
Old 01-13-2011, 02:00 PM   #9
I still am looking for views on the cost issue
Old 01-13-2011, 02:24 PM   #10
HVAC / Plumbing
It's hard to say if his prices are out of line. He's seen the job we have not. In my area you could call 5 plumbers & get 5 different prices. If I didn't like his price I would call someone for a 2 nd opinion
kenmac is offline   Reply With Quote
Old 01-13-2011, 04:15 PM   #11
this is a do it yourself forum, why don't you do it yourself? 1. call city, have water shut off 2. remove old valve. 3. Install new valve (Ball Valve). 4. Call city have water turned on. The details depend upon your piping i.e. copper, lead, cpvc etc.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
LateralConcepts (01-13-2011)
Old 01-13-2011, 06:00 PM   #12
Originally Posted by plumberinlaw View Post
this is a do it yourself forum, why don't you do it yourself? 1. call city, have water shut off 2. remove old valve. 3. Install new alve (Ball Valve). 4. Call city have water turned on. The details depend upon your piping i.e. copper, lead, cpvc etc.
Yeah in law that's the ticket, DIY save a bundle just pay for the material.
COLDIRON is offline   Reply With Quote
Old 01-13-2011, 07:17 PM   #13
And Still Learning
Sandra, is there a problem with your old valve? Just leave it there. I'm thinking that in Houston you service (main) line should not be deeper that 8-10 inches. With a the proper parts this is a one hour job.
Know It ALL is offline   Reply With Quote
Old 01-15-2011, 08:56 AM   #14
my ? is if it is in front of the meter it should be the water dept. to fix this please let me know good luck & God bless.
samps70 is offline   Reply With Quote
Water Softener started regenerating when I was changing the water filter nicksergeant Plumbing 0 11-07-2010 07:17 PM
Changing valve near boiler loop secutanudu Plumbing 10 09-29-2010 10:50 PM
Sewer Line Continues to clog. Just Some Guy Plumbing 16 08-24-2009 11:38 PM
Dynamics of 3" vs 4 " main sewer line 4just1don Plumbing 4 01-07-2009 08:01 PM
Hot Water Cross Over rjordan392 Plumbing 3 09-11-2007 01:33 PM
