-   -   cost - leak on main water line and changing valve (http://www.diychatroom.com/f7/cost-leak-main-water-line-changing-valve-92185/)
sandrashand 01-13-2011 10:59 AM
I have a small leak on my main water line going to the meter in front of my house....what cost should I expect for fixing that?
Also, the plumber indicated that it would be better to have a ball valve instead of a gate valve for the main water valve to the house, but he wants $375 to change it which seems way too high.
What should I expect as a cost?
Thanks!!!
broox 01-13-2011 11:08 AM
Where are you? How long is the run of pipe? Is he going to just repair the leak or replace the whole pipe? What material is the existing pipe? How deep is the existing water service?
Jackofall1 01-13-2011 11:15 AM
I would be careful using a ball valve, if not exercised regularly, ball valves, especially lower end ones, will seize, I believe this is why gate valves are used, they are almost indestructable.
fireguy 01-13-2011 11:16 AM
You are right, that price is way out of line. I suggest you hire someone from Craig's list.
sandrashand 01-13-2011 11:25 AM
I am in Houston, texas and he is going to replace a small section with pvc piping...he wanted to change the valve going to the water meter, but I read online that usually the city is responsible for both valves on either side of the meter....he wanted $569
As for the valve on the main water line at the house, he would just change the valve from gate to ball...for this he wanted 375$
LateralConcepts 01-13-2011 11:55 AM
No offense, but I think you're backwards on your thinking. Ball valves have far fewer problems, leaks, etc.
Bondo 01-13-2011 12:03 PM
Ayuh,... That's been my experince too....
I pretty much use nothing but ball-valves anymore...
Jackofall1 01-13-2011 12:09 PM
None taken, but I have seen process ball valves especially inexpensive ones freeze up because of lack of use, where a gate valve can usually be persuaded to move.
sandrashand 01-13-2011 01:00 PM
I still am looking for views on the cost issue
kenmac 01-13-2011 01:24 PM
It's hard to say if his prices are out of line. He's seen the job we have not. In my area you could call 5 plumbers & get 5 different prices. If I didn't like his price I would call someone for a 2 nd opinion
plumberinlaw 01-13-2011 03:15 PM
this is a do it yourself forum, why don't you do it yourself? 1. call city, have water shut off 2. remove old valve. 3. Install new valve (Ball Valve). 4. Call city have water turned on. The details depend upon your piping i.e. copper, lead, cpvc etc.
COLDIRON 01-13-2011 05:00 PM
Originally Posted by plumberinlaw (Post 569383)
this is a do it yourself forum, why don't you do it yourself? 1. call city, have water shut off 2. remove old valve. 3. Install new alve (Ball Valve). 4. Call city have water turned on. The details depend upon your piping i.e. copper, lead, cpvc etc.
:thumbsup::thumbsup::thumbsup: Yeah in law that's the ticket, DIY save a bundle just pay for the material.
Know It ALL 01-13-2011 06:17 PM
Sandra, is there a problem with your old valve? Just leave it there. I'm thinking that in Houston you service (main) line should not be deeper that 8-10 inches. With a the proper parts this is a one hour job.
samps70 01-15-2011 07:56 AM
carpenter
my ? is if it is in front of the meter it should be the water dept. to fix this please let me know good luck & God bless.
