Cost Of Basement Bathroom Rough-In - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2011, 11:35 AM   #1
Cost of Basement Bathroom Rough-In
We're interested in adding a half bath to our basement. The room would be about 10-12 feet from the waste stack (cast iron), which runs down from the upper floors into the basement (concrete) floor and out to the street. The plan is to put in a regular toilet (i.e. no ejector pit/pump unless it turns out to be necessary after the floor is broken up) and a pedestal sink or vanity.
I got two estimates from plumbers for roughing in the waste and supply lines, and wanted to see whether anyone here thought they were reasonable. The first estimate was $2500 and did not include breaking up or repairing the floor (but the plumber would scope out and mark the location of the pipe for me). The second estimate was for $3500 and included breaking up and repairing the floor.
I'm in the DE/PA/NJ area.
Thanks.
phillylex is offline   Reply With Quote
Old 09-15-2011, 09:24 PM   #2
Basement bath rough in
Had it done in my home two years ago. Had H/C supply lines rerouted. My guy also plumbed the sink and drain and cold water supply line for the closet. He also dug up the floor and tied in the waste line and finished the concrete work after the inspection. One plumber did it all, total price: just over $1500.00. I'm happy.
TCOTCC is offline   Reply With Quote
Old 09-16-2011, 07:53 AM   #3
Can I ask what part of the country you're in? Also, did he pull a permit?
Old 09-16-2011, 09:32 AM   #4
Plumb or Die!
I'd say reasonable. To the other guy, WOW that plumber (?) sure worked cheap.
plumber666 is offline   Reply With Quote
Old 09-16-2011, 05:49 PM   #5
Cost of basement rough in
I am in northeast Ohio. As I indicated, the work was inspected by the local building inspector. I am in a municipal city so building codes are enforced.
To Plumber666: My plumber happens to work for one of the best companies in the area. Are you feeling guilty?
Old 09-16-2011, 06:01 PM   #6
DIY staff
Rewards Points: 7,174
That's $500 cheaper than 20 years ago---you got a great deal.
Old 09-18-2011, 02:01 PM   #7
Plumb or Die!
Well, there's a rate for friends, then a rate for everybody else. Then one for cute chicks, then one for rich people. And on and on. Sometimes I'll even quote way way too high cause I don't want the work.
The Following User Says Thank You to plumber666 For This Useful Post:
VIPlumber (09-18-2011)
Old 09-18-2011, 03:03 PM   #8
AlbacoreShuffle's Avatar
Thanks.
Those estimates sound fair to me.
As a matter of fact they side a little on the low side.
AlbacoreShuffle is offline   Reply With Quote
Basement Bathroom questions zoolou Plumbing 8 01-06-2011 04:36 PM
From a rough to a bathroom Satori Plumbing 4 07-21-2010 06:52 PM
Basement bathroom floor n2learning Flooring 5 07-13-2010 11:55 AM
Adding a basement bathroom with sewage ejector pump qoncept Plumbing 5 07-13-2010 09:48 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 04:27 PM
