Corrugated Pipe Depth - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-29-2008, 04:38 PM   #1
Rewards Points: 1,088
I'm planning on installing 4" corrugated pipe to route water from the sump discharge pipe. How deep does this corrugated pipe need to be buried? I would think it does not matter, as long as the pitch away from the outlet is sufficient to route water away.
handy man88 is offline   Reply With Quote
Old 05-29-2008, 09:25 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You're right.
The key to any underground drain pipe is to also put it in a fabric sleeve made for the purpose to prevent it from eventually filling and clogging with dirt.
You also might consider ending the drain tile into a dry sump, such as a buried barrel filled with (broken) cinder blocks and bricks and covered with ground fabric for the same purpose.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 04:08 AM
drain pipe depth under concrete amakarevic Plumbing 4 07-27-2007 08:35 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
