Corrugated Drainage - French Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2012, 06:06 PM   #1
My basement is getting wet, my side yard has a depression that's about 15 feet in diameter.
I've dug a trench that's about 2 feet deep and 2 feet wide. I'm going to put plastic down in the bottom, some gravel, perforated corrugated pipe, (and an unperforated pipe for the gutters, more gravel, landscaping fabric on top, than soil, running down hill, and out the hill in my front yard.
Does this look okay?
Any suggestions appreciated!!
http://www.imageshack.us/photo/my-images/255/sidemb.jpg
http://www.imageshack.us/photo/my-images/6/topzr.jpg
rhino54004 is offline   Reply With Quote
Old 12-02-2012, 09:38 PM   #2
Rewards Points: 1,492
The perforated pipe won't do much good unless it is below basement floor level. (The trench bottom alongside the house may not be below foundation footing bottoms which means very little slope for the portion against the house.)
If this is too deep to reach the ground surface at the bottom of the hill then you need a sump pump which can dump the water into the nonperforated pipe.
Retaining Wall / French Drain Question bsmith95610 Landscaping & Lawn Care 8 05-18-2012 09:48 AM
French drain to stop yard drainage issue? andrewhkoehler Landscaping & Lawn Care 9 03-16-2011 08:46 PM
French Drain Help Please moze Landscaping & Lawn Care 19 02-16-2011 11:09 AM
French Drain or Trench Drain mikeylikesit580 General DIY Discussions 8 09-30-2010 11:17 PM
creating a french drain ks2 Building & Construction 2 03-07-2009 12:15 PM
