Old 01-08-2013, 12:03 PM   #1
corrosive action on this union hot side
Why would there still be corrosive action on this union hot side? The plastic bushing and rubber washer is in tact. I wiped it off so the corrosion is not showing. The old heater was in service 20 years no corrosion, same set up.
Just on the bottom of the union!
Hardway is offline   Reply With Quote
Old 01-08-2013, 12:06 PM   #2
Anodode rod is probaly long gone with a heater that old.
20 years is about 5 years behond the expected life of a heater, may want to concider replacing it.
Old 01-08-2013, 12:31 PM   #3
Roofmaster
What corrosion? I don't see any corrosion or electrolysis at all. All I see is solder tin Am I going blind Joe? Vat DA Hek Ar U Talkin Bout?
Admittedly, the guy cant focus (Macro Please) but aside from that, whaaaaaaaaaaaaaaa?
" A lot of men build things, and a lot of things fall down "
Old 01-08-2013, 10:20 PM   #4
That is a new heater, I wiped the corroison off. I will have to wait till or if it comes back and take a photo before I clean it off. Thanks for the response till next time.
Old 01-09-2013, 06:40 AM   #5
Super Moderator
Might be a tiny bit of seepage---the threads are just raw steel---they can pick up some rust from the atmosphere
Old 01-09-2013, 09:45 AM   #6
Roofmaster
I ALWAYS use anti seize compound on something like this. I pulled the anode on my new water heater prior to install, applied Nickel based Anti seize compound and reinstalled it. I picked this us while servicing burners on huge stills in refinery's. That stuff is worth its weight in Gold.
Old 01-09-2013, 02:18 PM   #7
I was thinking flux may have run down, it was a straight line run rust colored so who knows. I can't help but look at when I was clothes as it is right there.
Old 01-09-2013, 02:40 PM   #8
Roofmaster
When I was clothes? Thats it, no more lead fumes for you!
Old 01-09-2013, 06:04 PM   #9
Super Moderator
I've seen that area stained from the union--seep a bit and obviously was tightened----
"smooth" side on hardie backer amakarevic Building & Construction 2 04-12-2011 11:43 AM
Maytag Side by side dannykapp Appliances 25 02-27-2011 10:25 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Cape cod side attic insulation problems (fun) capecodfun Building & Construction 1 01-27-2011 02:49 PM
GE side by side leaking chrisn Appliances 0 08-16-2010 04:48 AM
