Corrosion On Water Heater Hot-side Nipple - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2013, 08:46 PM   #1
Corrosion on water heater hot-side nipple
I installed this water heater 9 months ago, and it already has what looks like corrosion on the hot connection. Suggestions on what could be the problem? It almost looks like the teflon tape has actually started to break down (the white residue), but there is surface rust in there too.
I'm not sure why the copper is black, but it's just the surface that does scrape off and this copper was reused so it could've been on there already. The copper was definitely not heated anywhere near this connection.
Insulating foam had been installed all the way down to the water heater (over this connection), which I've just trimmed back. Could that have added to the problem?
biglaz is offline   Reply With Quote
Old 10-14-2013, 09:09 PM   #2
Rewards Points: 13,960
Is that a dielectric nipple on top of the tank?
Old 10-14-2013, 09:15 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 788
I believe the groove in the nipple indicates dielectric nipple.
I bet you used only tape, huh.
You've got a reeeeally slow leaker
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
Benplumbing (10-14-2013), joecaption (10-14-2013), oh'mike (10-15-2013)
Old 10-14-2013, 09:18 PM   #4
Master Plumber
Benplumbing's Avatar
Maybe a little sloppy with the flux ; )
Benplumbing is offline   Reply With Quote
Old 10-14-2013, 09:24 PM   #5
Master Plumber
You're probably right and he probably screwed the female adapter on then sweat everything together.. Instead of pre soldering them..then screwing everything together
The Following User Says Thank You to Benplumbing For This Useful Post:
Old 10-14-2013, 09:31 PM   #6
It is a dielectric nipple. The female adapter was soldered piece of copper 12+ inches, allowed to cool, then screwed on.
Only used tape on the threads.
Old 10-14-2013, 09:33 PM   #7
Master Plumber
Pipe thread paste should be used as well over the tape
The Following 2 Users Say Thank You to Benplumbing For This Useful Post:
biglaz (10-14-2013), TheEplumber (10-14-2013)
Old 10-14-2013, 09:40 PM   #8
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Benplumbing View Post
...he probably screwed the female adapter on then sweat everything together.. Instead of pre soldering them..then screwing everything together
No one told me about that either (until after I screwed up a couple times).
"Some things need to be learned the hard way"
Old 10-14-2013, 09:44 PM   #9
I've never heard this before. Guess I have egg on my face. Thanks, guys.
The Following User Says Thank You to biglaz For This Useful Post:
Old 10-15-2013, 06:14 AM   #10
Rewards Points: 1,216
Don't be so hard on yourself, it will be OK for years.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Larger Water Heater + Small Water Heater BigJim Plumbing 8 03-03-2013 01:11 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
