Old 03-13-2012, 08:29 AM   #16
joed's Avatar
Corroded copper piping
Is that the bottom of the pipe? If it is then my guess is you have an acidic water. It has created a pin hole. The leaking water has caused the corrosion looking spot. You can also bet that the rest of your pipes about to do the same thing. Replumb with pex or install an acid neutralizer to reduce the issue.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-13-2012, 09:44 AM   #17
Civil Engineer
It is worth taking a step back and ask a few simple questions. Always good to understand the problem first, then the cause of the problem, then look at options, then pick an option. So let's start with the problem. You have a few spots of corrosion on your copper pipe. At this point, you don't know if there are more hidden areas of corrosion. You don't know what the cause of the corrosion is. You certainly don't know at this point what the best solution is.
So here are some thoughts on how to determine the cause of the problem.
1. The suggestion about cutting out a section of pipe and examining the inside is excellent. Once the section is cut out, you can determine if the inside is corroded, which should be fairly obvious. When my copper pipes corroded due to acid water, the insides were tuberculated (large copper flakes loose in the pipe). You could NOT tell this from the outside, all you saw were pinhole leaks, but once I removed the pipe and examined the inside, it was clear.
2. You can test the pH of your water. You can do this with litmus paper which is just a few dollars at a hardware store or a fish supply store. There is no point speculating on whether your water is acidic, basic or neutral when you can test it instantly for just a few dollars.
3. You can check the outside of the pipe for evidence of flux (flux is an acidic compound used to clean copper piping prior to soldering on fittings). Sometimes the plumber fails to wipe off the flux, and it can cause a reaction with the copper that causes corrosion over time. If there is flux remaining on the pipe, it may be possible to visibly see it on the outside.
These are three reasonable, simple and inexpensive steps to take before making a big move like deciding to replumb the entire house. Certainly you want to check the water for pH before deciding what type of pipe to use, as copper is not very good with acid water. If you do have acidic water, you can then evaluate the relative cost of putting in a neutralizer versus replacing the copper with an acid tolerant plumbing material like PEX.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Ravenworks (03-13-2012)
Old 03-13-2012, 04:06 PM   #18
Thanks all for the advice here!
Lance45 is offline   Reply With Quote
Tee into Copper Piping for Saniflo gilbo125 Plumbing 4 05-10-2011 06:16 AM
Questions on LPG piping and flaring copper Sampson Plumbing 3 12-14-2010 07:15 AM
pex vs copper piping sizes dichroic Plumbing 6 07-28-2009 10:35 AM
Copper Or Iron Piping? beatboy77 Kitchen & Bath Remodeling 2 01-03-2009 01:36 PM
Copper piping for central air lesrogo HVAC 6 05-22-2008 08:38 PM
