Is This The Correct Sealant For Black Gas Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2013, 05:09 AM   #1
Is this the correct sealant for black gas pipe?
Been remodeling my entire house and we replaced all the plumbing (among many other things).
We're at the point, where the gas stove is being installed and my installer (whom I hired) noticed that the plumber (hired by my GC) used this blue sealant (see pic). He said that sealant is only used for PVC pipes (irrigation, etc.) not for black pipe and it's against code.
He said for black pipes, "yellow mustard" or pipe dope is required (see pic of the can he brought).
Now that got me worried that the plumber used this blue sealant throughout all the black gas pipes so I checked. Yep, he did (see 3rd pic).
Is this against code? DO I have to worry about premature leakage? I'm thinking of hiring my own licensed plumber to do an inspection as there have been many problems with the GC during this project.
Is this the correct sealant for black gas pipe?-2013-07-13-17.59.34.jpg   Is this the correct sealant for black gas pipe?-2013-07-13-18.02.29.jpg
gilliganslin is offline   Reply With Quote
Old 07-15-2013, 05:18 AM   #2
Rewards Points: 14,020
http://www.rectorseal.com/index.php/rectorseal-no-5/
Old 07-15-2013, 08:37 AM   #3
I know what the rectorseal #5 is., I bought some yesterday to use.
I'll rephrase my question better: is it against code to use the blue (PVC) sealant for black gas pipes? Will this result in early failure of the pipes - leakage?
Thanks.
Old 07-15-2013, 09:05 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 818
The only way to know for sure is to read the labels on the can.
Sure Rector Seal is fine, but so are several other products.
The blue is probably Blue Magic- you might find your answer on line too.
Seems like there are very few pipe dope that aren't allowed on gas these days
Old 07-15-2013, 01:37 PM   #5
Rewards Points: 446
removed comment after researching
old_squid is offline   Reply With Quote
Old 07-15-2013, 01:50 PM   #6
Plumber
Rewards Points: 818
galvanized is ok but according to my gas code, it needs to be labeled as gas if it is more than 2 ft long
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (07-15-2013)
Old 07-15-2013, 02:18 PM   #7
Thanks.
I believe this is the sealant he used: http://www.jcwhitlam.com/pdf/IG-SPEC.pdf
I asked my GC to take a picture of the can.
The specs do say it's OK for Natural Gas but doesn't say steel pipes explicitly, only the following: ABS, PVC, CPVC, Delrin*, Zytel*, Fiberglass, Nylon, Polypropylene, Polybutylene, Polyethylene, Celcon**,Cycolac***, and all types of metal.
Is steel considered metal?
Old 07-15-2013, 02:22 PM   #8
Plumber
Rewards Points: 818
Yes, it's considered metal
The key is that it is ok for gas- not so much the pipe material
Gas will break down some pipe sealants- some sealants will breakdown plastics
You appear good to go in both cases
Sent from my iPhone using DIY Forum
Old 07-15-2013, 02:42 PM   #9
FClef's Avatar
Rewards Points: 160
Sealants come in all types of colors so the color doesn't matter. What does matter is if the sealant is approved for the application it is being used on. If it is approved for natural gas and LP gas uses as well as all metals then it is fine. A simple call to the plumber to ask what brand of sealant he used will answer any and all questions you or your contractor may have.
Here is a link for you so you can see the different colors and uses:
http://www.grainger.com/Grainger/pip.../N-85hZ1z0q1yr
FClef is offline   Reply With Quote
Sewer Back Up/ Pipe Relining Question newbinca Plumbing 9 05-10-2013 12:23 PM
How to Estimate Water Flow Rate in Copper Pipe arskiracer Plumbing 12 04-15-2013 08:50 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Correct thread sealant? Duane 70 Plumbing 2 01-11-2009 11:16 AM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
