Old 02-06-2008, 09:33 AM   #1
Correct Glue
Can you glue abs pipe to pvc pipe? If so what type of glue do you use?
bondoo7_99 is offline   Reply With Quote
Old 02-06-2008, 09:46 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Correct Glue
Yes with transition glue, green in color, restrictions in code applies to this type of glue, make sure you know what those are.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-06-2008, 05:36 PM   #3
Correct Glue
outside the building only
ranman469 is offline   Reply With Quote
Removal of old glue hstgonzo Remodeling 4 05-02-2008 04:34 PM
Why is my living room cement floor covered with black glue? sil Flooring 7 10-29-2007 11:03 PM
engineered hardwood installation; Floating or Glue? El Buey Flooring 4 08-17-2007 03:53 PM
no glue vinyl floor (armstrong) kirtland Flooring 8 04-30-2007 12:14 PM
