Is This Correct? Basement Bathroom Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2012, 02:46 AM   #1
Is this correct? Basement Bathroom Rough In
You can see that some of the framing is going over one of the floor drains. I have attached a few photos. Can this be done like this? I would appreciate any comments on what I should look out for. Thanks in advance.
luapo is offline   Reply With Quote
Old 12-09-2012, 06:27 AM   #2
DIY staff
Rewards Points: 7,174
That doesn't look like a drain-------is that the rough opening for a tub?
Old 12-09-2012, 08:35 AM   #3
Rewards Points: 582
you have to provide more information than that....is that 4"drain for commode????? if so its 2 close to wall ben sr
Old 12-09-2012, 10:50 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
That looks like a backwater valve- you need 100% access.
The Following User Says Thank You to TheEplumber For This Useful Post:
jaydevries (12-09-2012)
Old 12-09-2012, 11:43 AM   #5
Yes. Is it Ok that some of the framed wall is covering the opening. Thanks again for your help.
Old 12-09-2012, 12:00 PM   #6
Plumber
Rewards Points: 452
No, its not yet, you need to determine what is under the cover first. You may regret covering it.
oh'mike (12-09-2012)
Old 12-09-2012, 12:57 PM   #7
Roofmaster
Rewards Points: 2,172
Huh?????
It looks like you have a framing contractor that is following a plan rather than using his head and finding out what he is covering. The standard distance for a toilet is 12 inches from the finished wall, looks to me like you dont have that. Where are the shower/ lavatory pipes?
Old 12-09-2012, 04:15 PM   #8
Plumber
I dont see any vents .
DidIDoThat is offline   Reply With Quote
Old 12-09-2012, 04:36 PM   #9
Thank you every one for your input. I will clarify a few things. The basement is being framed and the bathroom is being left undeveloped. I just want to make sure that when everything is done that I won't be left with a big problem to complete the bathroom.
If you haven't noticed already I'm an extreme novice and at this point know very little about plumbing or framing. I do appreciate any help that is provided.
This is definitely the tub rough in. My question should have been - How far does the drain have to be from the framed wall? Is it OK that the some of the framing is overlapping the rough in? Does this look right?
Below is a couple of a couple more pics from ceiling where the water lines come in and the back wall. Does everything look good? Should there be anything else that I should look for?
I will measure the distance from the center of the drain to the wall. This should be 12"?
Old 12-09-2012, 05:00 PM   #10
Plumber
Rewards Points: 452
The reason I questioned your tub rough is that I didn't see a vent pipe for it's trap, and the fact that you're in a basement which, in my area requires the valve. A standard tub is 5ft long so the framed opening should be that or 60-1/4". The wall can be on that box, in fact, you may need to enlarge it some more when it comes to setting the tub.
The toilet needs to be 12" from center of pipe to finished wall- minimum.
If you're unsure about anything- just ask. Members here have a wealth of knowledge and are not afraid to share.
ben's plumbing (12-09-2012)
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 09:52 PM
Basement Bathroom buildit45 HVAC 0 10-10-2012 11:00 AM
Basement Bathroom Rough In - A Big OOOOOPS! Beepster Plumbing 8 01-16-2012 09:40 AM
how to rough in a bathroom in the basement.... superstar Plumbing 1 12-25-2011 08:49 PM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
