Is this correct? Basement Bathroom Rough In
You can see that some of the framing is going over one of the floor drains. I have attached a few photos. Can this be done like this? I would appreciate any comments on what I should look out for. Thanks in advance.
http://imageshack.us/a/img41/337/dscf3636lc.jpg http://imageshack.us/a/img803/845/dscf3634i.jpg http://imageshack.us/a/img577/7378/dscf3632r.jpg http://imageshack.us/a/img685/1884/dscf3630m.jpg http://imageshack.us/a/img19/8549/dscf3626k.jpg http://imageshack.us/a/img542/4726/dscf3624g.jpg |
That doesn't look like a drain-------is that the rough opening for a tub?
you have to provide more information than that....is that 4"drain for commode????? if so its 2 close to wall :huh::huh: ben sr
That looks like a backwater valve- you need 100% access.
Huh?????
It looks like you have a framing contractor that is following a plan rather than using his head and finding out what he is covering. The standard distance for a toilet is 12 inches from the finished wall, looks to me like you dont have that. Where are the shower/ lavatory pipes?
I dont see any vents .
Thank you every one for your input. I will clarify a few things. The basement is being framed and the bathroom is being left undeveloped. I just want to make sure that when everything is done that I won't be left with a big problem to complete the bathroom.
If you haven't noticed already I'm an extreme novice and at this point know very little about plumbing or framing. I do appreciate any help that is provided. Quote:
http://imageshack.us/a/img542/4726/dscf3624g.jpg Below is a couple of a couple more pics from ceiling where the water lines come in and the back wall. Does everything look good? Should there be anything else that I should look for? I will measure the distance from the center of the drain to the wall. This should be 12"? http://imageshack.us/a/img42/6769/dscf3646c.jpg http://imageshack.us/a/img9/3206/dscf3642o.jpg |
The reason I questioned your tub rough is that I didn't see a vent pipe for it's trap, and the fact that you're in a basement which, in my area requires the valve. A standard tub is 5ft long so the framed opening should be that or 60-1/4". The wall can be on that box, in fact, you may need to enlarge it some more when it comes to setting the tub.
The toilet needs to be 12" from center of pipe to finished wall- minimum. If you're unsure about anything- just ask. Members here have a wealth of knowledge and are not afraid to share. |
| All times are GMT -4. The time now is 02:22 PM. |
