Corner Tubs - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2012, 12:56 PM   #1
Corner Tubs
I'm considering installing a Corner Tub unit as part of major renovation.
Another member suggested some of the downsides of a corner tub in this thread.
I was hoping to get opinions from installers or homeowners who have experience with corner tubs. Any feedback is appreciated.
Also, these are the tubs that I'm currently considering:
American Standard 2775.018WC.020 Cadet 5-Feet by 5-Feet Corner Whirlpool with Everclean and Hydro Massage System-I, White - About $1600 w/ heater, looks like the most comfortable
Kohler 5454 - Also about $1600 - 54" instead of 60" to save space
Ariel Bath AM168 with waterfall faucet - $2500 but I wouldn't need to buy a faucet and has ozone disinfection, lcd touch screen, etc...
Any info on any of these models would also be appreciated. Thanks!
GottaFixIt is offline   Reply With Quote
Old 01-07-2012, 05:41 PM   #2
DIY staff
Rewards Points: 7,174
Only draw back to any deck mounted tub is that you can not use it as a shower----
If you don't hope to use it as a shower---they are a fine style of tub--
GottaFixIt (01-07-2012)
Old 01-07-2012, 06:08 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
What kind of hot water heater do you have? Hope it is either HUGE or a tankless one.
The Following User Says Thank You to Blondesense For This Useful Post:
Old 01-07-2012, 06:10 PM   #4
Thanks Mike.
I realize that it won't work as a shower and I'm OK with that.
Have you heard any complaints about them being uncomfortable or hard to get in and out of?
Old 01-07-2012, 06:11 PM   #5
Tank less. Good point though. Thanks!
Old 01-07-2012, 07:24 PM   #6
DIY staff
You need to find a showroom with one you can get into---the ones you posted were pretty big so I think you should be O.K.---But that is going to be there for a LONG time--so I'd want to try one on for size.
You don't have your location in your profile---so--you will have to look around---Kohler has a lot of showrooms scattered around the country--so I'd start with Kohler.
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 10:08 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
