Copper Y Fitting And Cabinet Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2011, 07:12 PM   #1
Copper Y fitting and cabinet install
I am ready to install a new kitchen cabinet but the 2" diameter copper sink waste line coming from the wall has a 'y' fitting on the end of it. I'm not really wanting to cut a hole in the back of the cabinets that is large enough to fit over the 'y' fitting.
Once countertops are installed we plan to have a professional plumber come back in and install the water lines and hook the waste lines back up.
Question is: What would be the best method for removing this fitting prior to installing the cabinet? 1.) Sawzall and cut it right at the edge of the fitting? 2.) Heat and use channel locks to loosen the fitting? 3.) Something else I hadn't thought of?
There is approximately 2.25" of pipe extending from the wall before the fitting. Once the cabinets are installed the will encompass 0.75". Is 1.5" of pipe protruding from the back of the cabinet sufficient for a plumber to connect a waste line?
Any assistance is greatly appreciated! Thank you in advance for your help!
brneilly is offline   Reply With Quote
Old 06-29-2011, 08:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
I'd heat it up and pull it if possible. But he should be able to connect to 1.5" as well. As a side note, double check your stub elevation. If your new sink is deeper or your adding a disposal, your stub out may be to high now. Easier to lower before the cabinet goes in.
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (06-30-2011)
Old 06-29-2011, 09:53 PM   #3
Thank you
It pulled off cleanly after about 1 minute of heat. Guess I shouldn't have been so gun shy about it. Thank you for the assistance!
Old 06-30-2011, 07:19 AM   #4
DIY staff
Rewards Points: 7,174
I hope you listened to the E-Plumber about the elevation-----Under mount sinks --extra deep with a garbage disposer often need a lower opening than in the old days.--Mike---
Old 06-30-2011, 10:13 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Also just one more thought : What kind of shape is the copper in? If it looks deteriorated, you might want to have him come BEFORE the cabinet goes in, and replace the part of the line that's inside of the wall.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
Best tool for tightening compression fitting Firehawk734 Plumbing 1 11-06-2010 01:23 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
New Kitchen required wedge22 Remodeling 22 09-04-2008 07:58 AM
