Copper Waste Pipe To ABS Schluter Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2010, 10:43 PM   #1
Copper waste pipe to ABS Schluter Drain?
Hello All...I am currently renovating my basement bathroom and have purchased a Shcluter Shower System. My question is whether or not and how I would be able to connect the 2" ABS Kerdi drain supplied with the shower system, to the 1-1/2" copper waste pipe which is currently 1/2" above the finished concrete slab.
Someone please tell me there is a safe and easy way to connect the 2 materials without breaking up the existing concrete slab.
Golfing Canuck is offline   Reply With Quote
Old 01-16-2010, 07:46 AM   #2
Rewards Points: 150
a 2" drain to a 1-1/2"waste ? is the copper line trapped ?
rudolph58 is offline   Reply With Quote
Old 01-16-2010, 09:09 AM   #3
I am assuming/hoping it is trapped. There is no access from beneath as the copper is embedded in the concrete slab. That being said The old shower was used regularly and we never experienced a problem with any type of smell coming through the drain.
Venting ponch37300 Plumbing 41 02-23-2013 10:37 PM
closet flange ....over the drain pipe or inside the drain pipe moegumble Plumbing 2 08-18-2009 07:09 AM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
