#16 |
Copper vs. CPVC
I really worry about places like my GF's 3 floor condo building. All cpvc, about 17 years old. That piece I worked on was soooo freakin' brittle. And the plumbing in the utility rooms is not very neat, the pipes not well supported.
She is on the ground floor but I really worry about someone on an upper floor moving a box on a shelf or whatever in their util room and whacking a pipe.... Or someone rooting around under their kitchen sink and snapping a cpvc water supply stub. Wouldn't take much. If that were to happen and if their inside shutoff valves don't work like my GF's old one there would likely be serious damage as the main shutoffs for the building are in a ground floor closet and not well labeled. Not sure if the residents even would know where to look. I like my copper but PEX looks very robust and a lot cheaper for new const. |
#17 |
Copper vs. CPVC
Do you use shark grip fittings with your pex? What other type fittings are there that can be used. I have watched plumbers re-plumb the house across from me that was totally demolished by the April tornado and the insurance company paid to rebuild it. They put in red and blue pex piping and used what they called a shark grip fitting. It looked simple enough to install.
What about coming from under your house up the wall and out to your commode for instance, do you just bend the pipe and not use fittings there? What about where the pex comes out and you hook up your service lines do you transition to galv there in order to make it straight or can you just heat the pex and make it stay straight permenantly? Tom |
#18 | |
Copper vs. CPVCQuote:
#19 |
Copper vs. CPVC
Yes, you certainly can use various types of press on connectors, like Sharkbite. This site has a lot of PEX tubing, fittings, compression rings, tools, etc. You can get a good feel as to what is available by browsing here:
http://www.pexsupply.com/?cmpid=ppc;...FQd_5QodgXaIqQ |
#20 |
Civil Engineer
Copper vs. CPVC
Copper has a few advantages, and several disadvantages. The advantages are ready availability, resistance to nicks, and natural antimicrobial action. There are some disadvantages, namely high cost (at $4 per pound for raw copper), low life expectancy in acidic water, and relatively high installation costs. In the right water environment, a properly installed copper piping system should last fifty years.
PEX has a number of advantages, and several disadvantages as well. The advantages are low cost per foot, ability to make continuous runs without fittings due to bendability, and long lifespan. The disadvantages include damage from sunlight (should never be used when exposed to direct sunlight), easily nicked by metal, and a history of brass fitting failure (see Zurn lawsuit and recent problems with Wirsbo brass fittings). As in most building discussions, individuals often have preferences built on personal experience, and not all beliefs are grounded in empirical fact. One thing for certain is that the market has a lot to say about what type of piping will be installed. The current high metal price environment makes PEX look pretty good. |
| The Following User Says Thank You to Daniel Holzman For This Useful Post: | DangerMouse (11-17-2011) |
#21 |
Copper vs. CPVC |
#22 |
Copper vs. CPVC |
| The Following User Says Thank You to Msradell For This Useful Post: | DangerMouse (11-17-2011) |
#23 |
Copper vs. CPVC |
#24 |
Remodeler
Copper vs. CPVC
This from wikipedia:
#25 |
Home Remodeler
Copper vs. CPVC
Cpvc is very easy to install and inexpensive. I installed it in my home 15 years ago and have had 0 problems. If I was doing it today I am not sure, but I would use Pex, I like the idea of not instaling all the 90s and 45s to install CPVC.
| The Following User Says Thank You to mikey48 For This Useful Post: | DangerMouse (11-17-2011) |
#26 | |
I not seen this happen with galvanized. (But I wouldn't care to plumb a whole house in galvanized! )
| The Following User Says Thank You to Billy_Bob For This Useful Post: | DangerMouse (11-17-2011) |
#27 | |
#28 | |
call me E
As for the OP's comments, PEX or copper. Stay away from CPVC if possible. Check your electrical bonding too if you go PEX and avoid exterior walls. |
#29 |
Copper vs. CPVC
DIYERS use mechanical fittings, guys that know what their doing use copper and solder fittings. That's not true in all instances because I know many plumbers that install whole house pex, I'm just saying for this forum.
That would probably be mostly true. |
#30 | |
Explain situation surrounding "check your elec. bonding too if you go PEX" |
| Display Modes | |
| CPVC Installation Questions | Pittsville | Plumbing | 24 | 01-30-2011 09:38 PM |
| Replacing old Copper with CPVC | epsilon | Plumbing | 1 | 06-21-2010 06:39 PM |
| Copper vs CPVC vs Pex | bwhite | Plumbing | 2 | 12-30-2009 07:59 AM |
| Copper - CPVC - PEX | AlbrightPM | Plumbing | 28 | 01-25-2007 07:43 PM |
| Joining cpvc to copper? | randalg | Plumbing | 5 | 12-03-2006 08:42 AM |
