Old 06-15-2012, 11:00 PM   #1
copper turning black
i was in a house and all the copper was black on the outside. it is on a well and there is no galvanized pipe in the system. i was wondering if it is a ph balance issue. or something else
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 06-15-2012, 11:49 PM   #2
Persona Non Grata
VIPlumber's Avatar
I believe that the well might have a high hydrogen sulphide content. Does the water have a strong rotten egg smell?
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
jaydevries (06-16-2012)
Old 06-16-2012, 01:16 AM   #3
not that i could smell. i did see that they had a magnetic filter then xx-large whole house filter,then water softener. would that get ride of smell.
Old 06-16-2012, 09:21 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Reminds me of the Chinese drywall issue. Are the electrical wires also turning black, along with the piping? Can you post pictures.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 06-16-2012, 05:49 PM   #5
Persona Non Grata
VIPlumber's Avatar
From what I understand when trying to get rid of H2S (hydrogen sulphide), it all depends on the amount present (ppm). If it's a fairly low concentration then I believe that a carbon activated filter should work. Other fixes include changing the anode in the water heater to magnesium, greensand filtration, aeration of the water, or chlorine injection/shocking the well with chlorine.
Or, as gregzoll mentions it could be the Chinese drywall issue. I haven't any experience with this however.
Old 06-16-2012, 07:58 PM   #6
dogris's Avatar
How would the water inside the copper pipe affect the outside surface of the pipe run?
dogris is offline   Reply With Quote
GE SunSmart Timer 15312 Install Issue stringzz Electrical 10 02-06-2012 09:17 PM
copper tubing turning green soldotnalady Plumbing 3 05-27-2011 08:39 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 01:52 PM
