Old 05-27-2011, 07:16 PM   #1
copper tubing turning green
Why is my copper tubing plumbing turning green . and how can i resolve this issue?
soldotnalady is offline   Reply With Quote
Old 05-27-2011, 07:58 PM   #2
Tileguy
Bud Cline's Avatar
[quote]
Because it is oxidizing, probably from the acids or flux used when solidering the joints originally. With copper yard ornaments or copper roofs or copper gutters and downspouts the green is actually prefferable and in those cases is called "patina". The green is usually harmless and nothing to concern yourself over.
Why would you want to?
Old 05-27-2011, 08:22 PM   #3
Super Moderator
Like Bud said--not a worry. Wash the pipe with soap and water and a green scrub pad if the look bothers you--otherwise it's harmless.
oh'mike is online now   Reply With Quote
Old 05-27-2011, 08:39 PM   #4
thanks ....I have been told by others that it was because it was eating the copper tubing from the inside out...I have been worried I would have to replace all my plumbing with that new plastic plumbing..whew!!!
The Following User Says Thank You to soldotnalady For This Useful Post:
oh'mike (05-28-2011)
Copper Pipe Turning Green marcoj32 Plumbing 20 04-15-2013 08:01 PM
plumbing copper for HVAC refrigerant lines? Mike in Arkansas HVAC 9 03-21-2010 09:52 PM
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 06:02 PM
PVC, copper, tubing? rodsteryz Plumbing 3 05-14-2008 05:22 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 11:47 PM
