Old 01-22-2011, 05:15 PM   #1
copper tubbing
Can I use silver solder for joints on soft copper for natural gas?
I was told I had to use flare fitting connections. Do I have to worry about the solder breaking down with
natural gas?
Thanks, Dan
dzimmerle is offline   Reply With Quote
Old 01-22-2011, 05:17 PM   #2
BIGRED
copper tubbing
Yes you can.
Grampa Bud is offline   Reply With Quote
The Following User Says Thank You to Grampa Bud For This Useful Post:
dzimmerle (01-22-2011)
Old 01-22-2011, 05:19 PM   #3
waterman1971's Avatar
copper tubbing
Thread title made me think of a tub
waterman1971 is offline   Reply With Quote
Old 01-22-2011, 05:27 PM   #4
copper tubbing
natural gas?
Thanks, Dan
Old 01-22-2011, 06:14 PM   #5
BIGRED
copper tubbing
If you are only soldering copper fittings and copper tubing -not tubbing- together then you can use plumbers lead free solder or silver solder as you choose. If you are thinking of replacing the flare fittings on appliances or valves with soldered fittings, in a word forget it. The flare fittings are there for a reason.
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 10:23 AM
copper flashing, galvanized nails... sharp Roofing/Siding 4 04-02-2010 07:43 PM
Copper hood - Looking for input steve1234 General Discussion 13 01-04-2010 02:34 PM
