Old 06-04-2008, 02:45 AM   #1
analogmusicman's Avatar
Default copper strap around copper pipe?
I notice that my copper pipe (1/2 in.) going to one of the bathrooms, has a copper strap to hold it to a stud. this is reasonable I guess (you probably don't want dissimilar metals touching each other) my question is why is the strap nailed with copper nails? any good reason?
tnx,
analogmusicman is offline   Reply With Quote
Old 06-04-2008, 02:54 AM   #2
now that I think about it, if my initial thought about dissimilar metals is valid, maybe we don't want anything dissimilar to copper fastening the strap to the stud.
tnx,
Old 06-04-2008, 10:50 AM   #3
Nice to know that some contractors go "all the way" when installing stuff. Although it may not cause a problem, after a while you would probably see a discoloration from the electrolysis.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-04-2008, 12:55 PM   #4
Building codes guy, Mod
thekctermite's Avatar
Yes, electrolysis is the enemy of copper water lines. Dissimilar metals in contact with each other will advance corrosion, especially in a pipe that has a constant flow of water. I think that copper nails is overkill, but the original installer was doing it right! These days you can use plastic pipe supports that work pretty well.
thekctermite is offline   Reply With Quote
More On This Topic
How to Fit Copper Pipes
How to Fit Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and back with you on copper piping. Here are he three pieces that we are going to put together. I've got the flux and we've got our torch ready to go, dry fitted them. We know that everything is fitted... Read More »
How to Sweat Copper Pipes
How to Sweat Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and we are working on our pipes. We have got pretty much everything ready to go. We have got our flux on. We have got our torch ready and our solder at hand and I am just going to fit these now and the flux... Read More »
Hey everybody Don Golden with Expert Village and we're moving on with our copper piping. I'm going to show you now what you need to join these in everlasting matrimony. What we are going to do is we are going to use what is called flux paste. This is a... Read More »
How to Dry Fit Copper Pipes
How to Dry Fit Copper Pipes by Expert Village
Hey everybody Don Golden here with Expert Village. We are talking about copper piping and copper fitting. We have prepped these two little demo pieces and the 90 degree union that I am going to show you how to sweat shortly but I got a little ahead of... Read More »
Hey everybody Don Golden for Expert Village and we are having fun with copper today, copper piping. We just put this joint together and I felt it was my duty to show you a new technology that really makes this even easier and it is pretty easy as it is... Read More »
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 08:25 PM
Copper Pipe Problems jvc120er Plumbing 8 04-15-2008 03:07 PM
How to protect 3/4" copper pipe passing through concrete Mike Warner HVAC 2 03-13-2008 02:37 AM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-13-2008 12:36 AM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 06:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
