-   -   copper strap around copper pipe? (http://www.diychatroom.com/f7/copper-strap-around-copper-pipe-21815/)
analogmusicman 06-04-2008 01:45 AM
I notice that my copper pipe (1/2 in.) going to one of the bathrooms, has a copper strap to hold it to a stud. this is reasonable I guess (you probably don't want dissimilar metals touching each other) my question is why is the strap nailed with copper nails? any good reason?
tnx,
analogmusicman 06-04-2008 01:54 AM
now that I think about it, if my initial thought about dissimilar metals is valid, maybe we don't want anything dissimilar to copper fastening the strap to the stud.
tnx,
majakdragon 06-04-2008 09:50 AM
Nice to know that some contractors go "all the way" when installing stuff. Although it may not cause a problem, after a while you would probably see a discoloration from the electrolysis.
Termite 06-04-2008 11:55 AM
Yes, electrolysis is the enemy of copper water lines. Dissimilar metals in contact with each other will advance corrosion, especially in a pipe that has a constant flow of water. I think that copper nails is overkill, but the original installer was doing it right! These days you can use plastic pipe supports that work pretty well.
