Old 09-08-2008, 12:47 AM   #1
Default Copper Soldering Problem
I'm just a DIY'er with copper plumbing. I appear to have a PH imbalance in my well water (another story) so my 30+ year old copper plumbing gets a few pin holes and have to be repaired. Over the past few years I've sucessfully repaired 5 or 6 a year. My usual problems with soldering have been due to water in the lines which I usually solve with some loaf bread in the line.
But this past weekend I cut a piece of 1/2 inch copper and was attempting to solder the couplings to it before attaching it to existing line. After 4 attempts I could not get the new piece to accept any solder in the coupling!
I sanded and cleaned both pieces (tubing and coupling), I used sand paper and steel wool and never touched it with my bare hands. I also fluxed both pieces. The solder just rolled off and would not go into the joint. So I ended up at lowes at 10PM buying plastic snap on couplings!
Could the flux have been bad? Can you get the joint too hot? Is steel wool bad for cleaning?
Like I said I'm not a professional plumber but i've never had this happen before!
thanks
Eric_ht is offline   Reply With Quote
Old 09-08-2008, 12:57 AM   #2
Building codes guy, Mod
thekctermite's Avatar
You more than likely overheated your flux and it liquified and rolled out of the joint. Overheating the joints sometimes lets that flux get out of parts of the joint, which can result in leaks over time due to poor solder coverage of the full depth of the joint.
I hate the grayish-black flux that comes in cans. I'd suggest getting a little pint tub of the amber-colored paste flux. It is nice and thick and seems to be a little more forgiving with heat than the black stuff.
Sounds like you know the bread dough trick, but water or steam can cause the joint to never heat correctly and you'll never get solder in it. Might double check that and wad up some bread in there just for good measure.
thekctermite is offline   Reply With Quote
Old 09-08-2008, 01:03 AM   #3
Thanks Mite. The flux was an amber/brown looking stuff. I've always wondered about heating it too much. I think I tend to over heat it, thinking the hotter it is the better the solder will melt and go in. I'm probably over looking the importance of the flux. It just seems the flux seems to start dripping out after a few seconds and the joint isn't hot enough? This piece was being soldered while it was off the main line so water was not a problem on this one.
Old 09-08-2008, 01:38 AM   #4
Some flux will always drip out when the copper gets hot. Be sure you're fluxing the pipe as well as the inside of the fitting thoroughly. I like to use a lot, but I can't honestly say whether it helps or not.
My suggestion is to keep touching the solder to the joint until it melts and gets drawn in by the flux. That way you're not heating too long before you try getting the solder in.
It takes practice, but you'll get it.
Old 09-08-2008, 10:17 PM   #5
Eric:
Here's the $64,000 question:
Did you provide a route for the hot pressurized air inside that pipe to escape?
You see, it is capillary pressure that sucks the molten solder into the joint. However, as you heat that joint, you heat the air inside the pipe too, and that results in an increase in pressure inside the pipe UNLESS you provide some path for that pressured up hot air to escape OTHER THAN the joint you're trying to solder.
I expect what happened is that when the joint heated up, the air pressure inside the pipe pushing the flux out of the joint was stronger than the capillary pressure wanting to suck molten solder into the joint. The air pressure won, and you lost.
Just remember that there always has to be a way for the air pressure that builds up inside the pipe to be released so that capillary pressure doesn't have to fight an uphill battle to pull the solder into the joint.
Nestor_Kelebay is offline   Reply With Quote
More On This Topic
Tips for Soldering Flux
Tips for Soldering Flux by Expert Village
Hi we're talking about copper foiling today. And specifically right now I'd like to break down for you a couple of the tools and chemicals that we're using. When you get a little bit much of an Excess of your Flux on your panel or an excess of Solder as... Read More »
Hi! This is Diana for expertvillage.com and today we are making a copper plant hanger for your back yard. So we have our copper pieces cut and where we are going to solder them together, we flattened the edges and now we are going to use what we call... Read More »
How to Use Copper Pipe
How to Use Copper Pipe by Expert Village
Hey again, Don Golden for Expert Village. We just had a lot of fun working with this copper pipe and I showed you how to put it together, how to clean it and what you want to use it for. Now again, this application really was just for demonstration. This... Read More »
Hi! This is Diana for expertvillage.com and we are going to solder the second part of our copper tubing plant hanger. This is the little ring we are soldering right in the middle of the front and that is going to hold your ceramic pot. I've got flux on... Read More »
Hi! This is Diana for expertvillage.com. We have our torch going, we have our piece of solder and now we are going to solder this piece together. We have the flux on it, hold the flame down onto the metal and touch the solder to it. When the solder gets... Read More »
diagnose house wiring problem brhodewalt Electrical 7 05-06-2009 11:03 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 02:08 PM
Any problem with concrete poured over copper pipe? Mikej-22 Building & Construction 5 03-18-2008 09:43 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
