Copper Re Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2010, 02:29 PM   #1
Rewards Points: 37
Copper Re Pipe
Hello all,
I'm going to attempt it..our new house is a small 900 sq foot place with old galvanized steel pipes. I'm going to replace everything until the shutoff right outside the house (not the one at the street). I plan on using a dielectric union between the two.
One question, I was under the house yesterday, and I noticed that in the kitchen the supply pipes go into the faucet, but they also T and go up towards to back of the sink ?!?!. I've never seen this before, I was thinking of just replacing to the sink and forgetting watever that T would go to. any idea on what it could go to? there's no dishwasher..
Thanks all.
aminus21 is offline   Reply With Quote
Old 07-26-2010, 05:10 PM   #2
Retired Plumbing Cont.
Could be air chambers.
rockerjockey is offline   Reply With Quote
Old 07-26-2010, 08:18 PM   #3
I agree. Sounds like "economy" water hammer preventers. In Florida, we had to extend all water lines up at least 8" above the fixture take-offs. These pipes were capped to make an air chamber.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-27-2010, 03:31 PM   #4
Rewards Points: 37
So I suppose I don't need to do that?
Old 07-27-2010, 04:25 PM   #5
They have a purpose, but are not required in most places.
Old 07-27-2010, 04:37 PM   #6
Rewards Points: 37
Thanks..
Also, for the shower, I don't want to retile right now, so would it be ok to throw on a 1/2 dielectric union and keep the steel pipes that go into the shower? I plan on doing the same at the main line right outside the house (with a 3/4" dielectric union)
also, can i cut the steel pipes with my 4 1/2" grinder and diamond blade? what else do people use to cut?
thanks all, you guys are making this go smooth..
Old 07-27-2010, 04:50 PM   #7
Rewards Points: 37
I guess I can use a sawzall to cut the old pipes too?
I ran up on this, but I think I'd only need something that smooth for new pipes. http://www.extremehowto.com/xh/artic...ticle_id=60299
Old 07-27-2010, 08:15 PM   #8
Owner
LateralConcepts's Avatar
Make your life easy and use PEX. With all the money you'll save on copper pipe, fittings, and dielectric unions, you'll be able to purchase PEX tools, i.e. crimper and cutters, and have some cool new tools to add to your arsenal.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 07-28-2010, 02:10 AM   #9
Rewards Points: 37
I'm not planning on using PEX. Here, PEX has a really bad name, most plumbing stores don't even carry it. Rumor has it that rats can eat into it. I know code may allow it in some places, but here in SoCal, not many people use it.
I cut the wall on the other side of the bathroom sink, and low and behold, you guys were right! The supply pipes for the bathroom sink T-up about 10 inches, and are capped off. I took a pic.
Do I need to do this with the copper? My old house (although it had newer copper plumbing) was not like this. Thanks again guys =)
Old 07-28-2010, 09:42 AM   #10
It might be a good idea to have at least one set of air chambers somewhere on the system, but not necessarily at the sink. We usually put them above the water heater stub outs on new work. Some pressure balanced tub valves require them in order to work properly, Moen being one. I would leave them off for now. You can always add a hammer arrestor at the fixture supply later if needed.
Copper Pipe Turning Green marcoj32 Plumbing 27 09-22-2014 11:10 PM
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 10:06 PM
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-14-2011 12:48 AM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 06:44 PM
Copper galvanized pipe corrosion bluefitness Plumbing 2 07-10-2009 11:02 AM
