Copper Or Plastic? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2008, 06:39 PM   #1
Copper or plastic?
I would appreciate some advice. I am getting quotes for replacing my old galvanized pipes. Some have offered the option of using a type of plastic (?) piping vs. copper. Apparently it may save on man hours, but I'm a little hesitant going with something I haven't heard much about. Any input would be great!
k.kuenn is offline   Reply With Quote
Old 09-05-2008, 06:47 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
If the plastic is PEX tubing, an unqualified yes. It is the way of the future. Material is half the cost of copper and the labor is at least 20% less. Has been used in Europe for over 30 years, USA in the last 10 or so.
If they are talking CPVC, I would not prefer over copper.
Old 09-05-2008, 09:05 PM   #3
the Musigician
DangerMouse's Avatar
i'd much rather put in pvc and cpvc than copper ANY day of the week. pex is cool too, but more pricey than the pvc. i did my whole house with pvc/cpvc (cold/hot) in less than a day. but if i'd gone copper, i'd have had a heck of a time sweating connections where i had to work! (crawl space, tiny area behind tub, etc.) primer, then glue and it's done. and not one leak anywhere in 5 years. too cool.....
DM
Old 09-05-2008, 10:44 PM   #4
Rewards Points: 1,088
DM
Pex by far is the easiest to run. Imagine routing flexible hose through your house. What's easy for the contractor may not be better for the homeowner though, with regard to the product.
Time will tell whether it will ever be found that plastic pipes, be they cpvc or Pex, leech chemicals that are deemed harmful.
handy man88 is offline   Reply With Quote
Old 09-06-2008, 04:36 AM   #5
747
registered
747's Avatar
Rewards Points: 534
If your going pex make sure they expand the pex for connections and not contract. I think expanding is better then contracting or crimping. It can be done either way. Let me explain further. If you have the expansion tool it expands the pex so you can insert the connection. The pex then has a memory which will make it go back to the original size. The other tool is a crimping tool if you will. I don't think thats the way to go.
747 is offline   Reply With Quote
Old 09-06-2008, 06:51 AM   #6
pex gets a big yes copper would be my next choice then pvc
I did my whole house in pex in about a day love the stuff and it is alot cheeper then copper
clasact is offline   Reply With Quote
Old 09-06-2008, 07:48 AM   #7
the Musigician
working in tight areas with a blowing flame around wood and cobwebs just kinda scares me is all...... but slap some glue and push is easy.
when i did my plumbing here, i'd never seen or even heard of pex, or i'd have certainly given it a try if it had been as cheap/cheaper than pvc. it's much easier to work around things! (no elbows, etc.) i always wondered before they made the stuff why you couldn't run 'pipes' with garden hose type stuff? i guess someone else had the same thought!
DM
and i agree with handyman on the 'time will tell' for leeching, but heck by the time they discover there is a tiny bit and ban it, we'll all probly be dead anyways. lol
Old 09-06-2008, 09:14 AM   #8
the Musigician
welp, here's someone that needs chastising.... no spamming here.... sorry, i don't imagine ANYone here is stupid enough to click your links....
DM
is a US penny in scrap worth more than US$0.01 ? amakarevic Off Topic 9 10-25-2008 09:11 PM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 09:47 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 01:40 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 10:29 PM
