Old 12-29-2009, 02:42 PM   #1
Copper pipes - do i have a problem? Pics!
Please see the below pictures.
Does this look like it's a problem? or is this from the plummer being lazy.
thanks!
redpen is offline   Reply With Quote
Old 12-29-2009, 03:57 PM   #2
Remodeling Contractor
This joint was poorly due. Looks like too much flux was used. I would replace it, but if not leaking you do not need too.
Old 12-29-2009, 05:40 PM   #3
It's not whats outside the joint its whats inside the joint that counts the outside of a joint does nothing to hold it together.
Agree with Bob.
SULTINI is offline   Reply With Quote
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 09:10 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 09:18 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
wire next to copper plumbing pipes abc Electrical 6 02-02-2008 12:01 PM
