Copper Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 06:31 PM   #1
Question
copper pipes
i replaced my water line from the street, about 600 ft. with copper flex line and now all the tubs, showers and sinks are turning green?? HELP!! i was told it would go away by the plumber and also the water district is putting too many chemicals, bleach, in the water.
it has been 4 years and it isn't any better. i can hardly get the bathrooms clean no matter what i use. i am not suppose to use comet kind of products on the tubs, but i am desperate!!
does anyone have an idea or solution????
tunaswootz is offline   Reply With Quote
Old 07-25-2009, 08:09 PM   #2
"Copper turns green when it oxidizes."
Here's my general search
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
Here's a link that may help
http://en.allexperts.com/q/Water-Qua...ter-stains.htm
"Green/Blue stains indicate copper problems that could be caused by electrolosis [electrolysis]. Do you happen to have any galvanized fittings in your plumbing?"
Old 07-25-2009, 09:51 PM   #3
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Copper pipes
OR YOU COULD HAVE A LOW LEVEL ELECTRIC SHORT GROUNDING TO YOUR
COPPER PIPES ! ! !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 07-26-2009, 10:39 AM   #4
COPPER PIPES ! ! !
In which case a clamp-on ammeter would show excessive current flow in the pipe. But how amps or milliamps is excessive?
Old 07-26-2009, 02:17 PM   #5
COPPER PIPES ! ! !
we have already put things on the pipe for electrolysis and we have no galvanized pipes, copper to pvc.
we a in an older modular and my husband thinks there is not a proper ground in place under the mobile. that is the next step.
TY
Old 07-26-2009, 02:27 PM   #6
MACPLUMB's Avatar
Copper pipes
TY
YES THAT IS WHAT I AM TALKING ABOUT ! !
Old 07-26-2009, 02:28 PM   #7
[quote=tunaswootz;306980]we have already put things on the pipe for electrolysis and we have no galvanized pipes, copper to pvc.
i have an amp meter. the copper comes to the mobile and then connects to the pvc going into the mobile.
i just went out and touched the connection from the copper to the pvc and it was leaking. when i stopped it did also, so there is a repair there.
do i put the amp meter on the copper pipe anywhere or ??
my husband is out of town or i'd ask him.
Old 07-26-2009, 04:03 PM   #8
For every 900' of Romex in your place you should have 5 mA of AC current flowing in the ground lead.
Old 07-26-2009, 05:35 PM   #9
TY
Old 10-11-2014, 08:36 PM   #10
Rewards Points: 2
Is there something to put on copper pipes to neutralize bleach that was sprayed on the copper pipes??
koi1farmer is offline   Reply With Quote
Old 10-11-2014, 09:42 PM   #11
Rewards Points: 2,550
Have you tried CLR?
Bob Sanders is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 09:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 08:20 PM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 09:18 AM
