-   -   copper pipes (http://www.diychatroom.com/f7/copper-pipes-49620/)
tunaswootz 07-25-2009 06:31 PM
copper pipes
i replaced my water line from the street, about 600 ft. with copper flex line and now all the tubs, showers and sinks are turning green?? HELP!! i was told it would go away by the plumber and also the water district is putting too many chemicals, bleach, in the water.
it has been 4 years and it isn't any better. i can hardly get the bathrooms clean no matter what i use. i am not suppose to use comet kind of products on the tubs, but i am desperate!!
does anyone have an idea or solution????
Yoyizit 07-25-2009 08:09 PM
"Copper turns green when it oxidizes."
Here's my general search
http://www.google.com/search?hl=en&s...&aq=f&oq=&aqi=
Here's a link that may help
http://en.allexperts.com/q/Water-Qua...ter-stains.htm
"Green/Blue stains indicate copper problems that could be caused by electrolosis [electrolysis]. Do you happen to have any galvanized fittings in your plumbing?"
MACPLUMB 07-25-2009 09:51 PM
Copper pipes
OR YOU COULD HAVE A LOW LEVEL ELECTRIC SHORT GROUNDING TO YOUR
COPPER PIPES ! ! ! :thumbsup:
Yoyizit 07-26-2009 10:39 AM
In which case a clamp-on ammeter would show excessive current flow in the pipe. But how amps or milliamps is excessive?
tunaswootz 07-26-2009 02:17 PM
we have already put things on the pipe for electrolysis and we have no galvanized pipes, copper to pvc.
we a in an older modular and my husband thinks there is not a proper ground in place under the mobile. that is the next step.
TY
MACPLUMB 07-26-2009 02:27 PM
Copper pipes
TY
YES THAT IS WHAT I AM TALKING ABOUT ! ! :thumbup:
tunaswootz 07-26-2009 02:28 PM
[quote=tunaswootz;306980]we have already put things on the pipe for electrolysis and we have no galvanized pipes, copper to pvc.
i have an amp meter. the copper comes to the mobile and then connects to the pvc going into the mobile.
i just went out and touched the connection from the copper to the pvc and it was leaking. when i stopped it did also, so there is a repair there.
do i put the amp meter on the copper pipe anywhere or ??
my husband is out of town or i'd ask him.
Yoyizit 07-26-2009 04:03 PM
For every 900' of Romex in your place you should have 5 mA of AC current flowing in the ground lead.
tunaswootz 07-26-2009 05:35 PM
TY:no:
koi1farmer 10-11-2014 08:36 PM
Is there something to put on copper pipes to neutralize bleach that was sprayed on the copper pipes??
Bob Sanders 10-11-2014 09:42 PM
Have you tried CLR?
http://www.canac.ca/upload/public/Im.../102476-v1.jpg
