Copper Pipe Vs Copper Coil Tubing For Refrigerator Water Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2012, 09:03 AM   #1
Rewards Points: 29
Copper Pipe vs Copper Coil Tubing For Refrigerator Water Line
Is there anything I should be concerned about when using copper coil instead of copper pipe when plumbing a refrigerator water line box?
I am planning on soldering a T in an existing cold water line, and then comming off with the coil to minimize the soldering.
kaalapurushha is offline   Reply With Quote
Old 10-15-2012, 11:00 AM   #2
Rewards Points: 13,270
Install one of these in the wall then use a stainless steel braded line made just for this.
http://www.bing.com/images/search?q=...6258B7&first=1
Old 10-15-2012, 08:09 PM   #3
Rewards Points: 1,442
Don't bend the copper coil repeatedly. Copper coil lets you bend to fit the location but once you install it, avoid bending it any more. It helps to have a shutoff valve on the pipe coming out of the wall, and you disconnect the copper coil each time you need to pull the refrigerator away from the wall for cleaning behind.
By having a lot of extra back there coiled up you can pull the fridge a little way from the wall so you can reach in more easily with the wrench and disconnect it and it will be springy enough to not bend in the process.
Old 10-15-2012, 09:59 PM   #4
Rewards Points: 700
Take a good look at other products for this application. Example: 1/4" plastic tubing similar to Pex has been used successfully, when installed correctly, for 5 decades or more. Copper will deteriorate for a number of reasons. This one failed where it penetrated sheet rock on its way to the ice maker. I swear some copper fails because it was installed in the wrong sign of the zodiac. No more for me.
where do I set the black o- ring on the tub spout? or the threaded copper pipe? radioflyer77 Plumbing 1 07-05-2012 10:23 PM
Bent soft copper pipe slkarns Plumbing 3 05-05-2012 12:00 AM
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 05:32 PM
Copper line for refrigerator being used as a ground... seannymurrs Plumbing 2 02-08-2011 10:11 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
