Copper Pipe Type For Residential Water Distribution - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2007, 07:42 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
Copper pipe type for residential water distribution
Hey there-
In addition to redoing all of my black iron gas lines (see other post), I'm also redoing all of the water distribution piping in my house (here in Oak Park, IL). The local BORG sells types K, L and M. From my reading I understand that type K has the greatest wall thickness and is typically used for burial applications, L is somewhat smaller and M is the smallest.
Is the type that is allowed for a given home dictated by the uniform plumbing code (or one of the others) or by the local code authority?
Thanks,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 12-30-2007, 07:55 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You're right. K is for underground supply service, and L is the next thickest wall copper pipe (used in commercial and residential), and M is OK for residential interior supply pipes. Contact your local Building Inspection Department for confirmation of what you're allowed to use where in your jurisdiction.
No matter what the pipe wall thickness (K, L or M), all of the fittings all have the same ID to fit any type of the same size pipe exterior dimensions...1/2", 3/4", etc.
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-30-2007, 08:16 PM   #3
section 604.2 type L
exception type M may be used for piping above ground in or on a building. and in ground outside the building
from the 2006UPC
yes you can
ranman469 is offline   Reply With Quote
Old 12-30-2007, 09:08 PM   #4
Send a message via AIM to Marlin
Check with your local building department. Here M is only allowed for use in closed systems (mainly heat), everything else above ground must be L.
Marlin is offline   Reply With Quote
Old 12-30-2007, 09:46 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
You could use pex.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-31-2007, 08:15 AM   #6
Master Plumber
Rewards Points: 150
What's a BORG?
jpplumber is offline   Reply With Quote
Old 12-31-2007, 08:53 AM   #7
Rewards Points: 566
Originally Posted by jpplumber View Post
What's a BORG?
Big Orange Retail Giant. They come to town and assimilate all the small mom and pop hardware stores, a la Star Trek. Also note the similarity between the term "Big Box" and the shape/size of the Borg warship!
Old 12-31-2007, 09:39 AM   #8
Union HVAC Tech.
Use type "L" and you'll be fine.
bigMikeB is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
How to cap copper water pipe Ryan Plumbing 8 09-27-2008 04:44 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
