Copper Pipe Turning Green - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2008, 03:11 PM   #1
I'm in the process of renovating my bathroom and had a plumber reconfigure my tub/shower plumbing to accommodate my new shower system. Today I noticed a green discoloration around the some of the copper pipes he sweated. I associate green and copper with water, however I don't see or feel any water leaking. Is this something to be worried about. I'm about to secure the area with durock and tile and would hate to tear it down because of a water leak.
marcoj32 is offline   Reply With Quote
Old 09-20-2008, 04:36 PM   #2
concretemasonry's Avatar
Rewards Points: 2,640
Copper will oxidize and you are seeing the "patina" that people pay lot for on flashing and downspouts. - They even try to accelerate it.
concretemasonry is online now   Reply With Quote
Old 09-20-2008, 04:36 PM   #3
Registered User
Termite's Avatar
It is nothing to be concerned with. Not uncommon.
Old 09-21-2008, 11:10 AM   #4
Hey guys,
Thank you very much. I appreciate your prompt and informative replies.
I LOVE THIS SITE!!!!!!
The Following User Says Thank You to marcoj32 For This Useful Post:
r0ckstarr (04-15-2013)
Old 09-21-2008, 12:53 PM   #5
Most of this is a chemical reaction called patina, as others have stated. You will normally find this around fittings and pipe that have been soldered. Many Plumbers do not wipe the joints after sweating and the left-over flux causes this. I always wipe the joint, first with a gloved finger for the look of the joint, and later with a wet rag to remove the excess flux.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-21-2008, 06:36 PM   #6
Rewards Points: 150
I would get the water tested for it's PH level, Water with a high acidic level will eat the copper pipe from ther inside out. Before you can realize it you will have pin hole leaks all over the house. That green is the copper being eaten away. I would bet you need an acid neutralizer and directly after that, a water softner. Take a water sample to Sears and have them test it, They will set a system up for you. Then shop around. I had the same problem and this set up fixed it. Oh and after cutting a piece of copper pipe out to see the condition of it internally i was amazed at how bad the pipe was pitted inside.
James Con is offline   Reply With Quote
Old 09-21-2008, 08:30 PM   #7
James,
It's not visible on the other pipes, only the ones that were sweated. I'm kinda agree with the other (came from the flux). It happened around 3 weeks after the pipes were sweated
Old 09-21-2008, 08:55 PM   #8
Registered User
Termite's Avatar
Originally Posted by marcoj32 View Post
James,
Bingo. I see it EVERY DAY in new construction. It happens, and is nothing to be overly concerned with.
Old 09-22-2008, 09:12 AM   #9
Rewards Points: 156
self cleaning flux
That self cleaning flux will patina really quickly even if you do wipe it down after soldering.
jayp is offline   Reply With Quote
The Following User Says Thank You to jayp For This Useful Post:
Bob Sanders (09-22-2014)
Old 09-22-2008, 09:47 AM   #10
Jayp, most of the 'patina" is caused from the heat of the torch. If you leave the melted flux on the pipe, it will, itself, turn the pipe green from the acid in it.
Old 09-22-2008, 05:35 PM   #11
the pipe master
protechplumbing's Avatar
In my experience large quantities of flux left on copper will weaken the pipe and encourage pin-holes to form years later. Remove it from the pipe using a dish soap and water mixture on a rag.
protechplumbing is offline   Reply With Quote
The Following User Says Thank You to protechplumbing For This Useful Post:
jaydevries (09-22-2014)
Old 09-24-2008, 09:00 PM   #12
green at fitting is not bad your plumber didnt clean the flux off when cleaning the 90's
doo-man23@comcast.net is offline   Reply With Quote
Old 05-27-2011, 06:22 PM   #13
thanks for all the information . My pipes are completely covered in green. i don't know how serious this is. Can anyone tell me just what to do before pin holes appear???
soldotnalady is offline   Reply With Quote
Old 05-27-2011, 07:04 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Jheeeezh now you have two identical threads going at the same time. I feel a little foolish replying to your other thread before I found this one.
XXX
Old 05-29-2011, 01:08 PM   #15
the pipe master
The dammage has been done. There is just as much flux on the inside of the pipes. If your water supply has the right water chemistry, the oil based flux will eat them from the inside out.
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 06:25 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 08:54 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-28-2005 11:05 PM
