Copper Pipe Size Change - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2013, 02:49 AM   #1
Rewards Points: 31
Copper pipe size change
I have a bathroom being supplied by 1/2 inch copper on a trunk that branches to 1/2 copper to the fixtures. The cold line continues and then transitions to a 3/4 inch line that supplies an outdoor spigot. Is this ok? I've always thought lines were supposed to get smaller, not larger. Also , should I change the trunk line to 3/4 inch?
Outdoorbum is offline   Reply With Quote
Old 05-27-2013, 03:22 AM   #2
Are you having a problem with this line?
hvac benny is offline   Reply With Quote
Old 05-27-2013, 07:16 AM   #3
Rewards Points: 582
need to see a picture of set up ...which direction is the flow comming from and volume it needed to supply demand of house...ben sr
Old 05-27-2013, 08:47 AM   #4
Rewards Points: 12,856
And your right, from the main supply the line should have been 3/4 all the way to the end with 1/2 lines coming off of that to your supplys.
Adding 3/4 to the end would useless.
Old 05-27-2013, 08:49 AM   #5
Rewards Points: 4,784
There shouldn't be a problem with that. Usually there's no problem going smaller to bigger. There can be problems going bigger to smaller, especially on your drain pipes. You also wouldn't want to do something like patch a 3/4" supply pipe with 1/2". Then you'd be going from bigger to smaller where it forms a bottleneck. Going from 3/4" to 1/2" from your main supply line to a fixture doesn't cause a bottleneck for the rest of the system. Neither does going from 1/2" to 3/4" to a fixture.
jeffnc is offline   Reply With Quote
Old 05-27-2013, 11:07 AM   #6
Rewards Points: 31
No, not having problems with anything. Just currently starting a bathroom remodel and I'm under the house examining how things were done . I'm a total amateur but studied it and wondered why, unless the outdoor spigot only accepts a 3/4 inch line and they decided to transition where I'm looking . There are tees that go to a now defunct solar water heater , so figured this would be a good place to install some shutoff valves, as the tub currently has none and an access panel would be tough.
This would shutoff water to the whole bathroom, but its a convenient location
Old 05-27-2013, 11:39 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 352
If you are going to be remodeling the bath- I'd run the branch piping 3/4" with 1/2" to the fixtures. You can reduce the branch line to 1/2" for the last 2 fixtures as a general rule.
Some hose bibs are designed to except 3/4 or 1/2" pipe- sounds like the installer chose the 3/4 route.
Pipe size increasing is not an issue at the bib
The Following User Says Thank You to TheEplumber For This Useful Post:
Alan (05-27-2013)
Old 05-27-2013, 01:11 PM   #8
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Outdoorbum View Post
I have a bathroom being supplied by 1/2 inch copper...
The day the house was being plumbed:
Helper: Hey Bob, these hose spigots are all 3/4". What should I do?
Plumber: Oi. Go out to the truck and get some 1/2 x 3/4 adapters. Use 'em.
Helper: It won't matter?
Plumber: Nope.
The Following User Says Thank You to TarheelTerp For This Useful Post:
ddawg16 (05-27-2013)
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-28-2010 12:42 AM
correct size pipe for water lines jce Plumbing 2 04-11-2010 09:23 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
