Copper Pipe Re-soldering - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2010, 08:15 PM   #1
Rewards Points: 38
Copper pipe re-soldering
I want to extend the lower 2 pipes approx 1 ft and replace this tap with one with standard compression fittings. Can I unsolder and replace the pipes from the lower portion of the Tee without loosening the other joints on that Tee? I guess the other option is to unsolder at the tap and extend down from there or cut a couple inches below the joint but the bend may cause a poor joint.
Martik777 is offline   Reply With Quote
Old 11-23-2010, 08:21 PM   #2
if you dont have experience unsoldering, then I would say to cut the copper a couple inches below the joint and couple on what ever you need
Ltnicks is offline   Reply With Quote
Old 11-23-2010, 08:21 PM   #3
HVAC / Plumbing
It may melt the solder but it should be ok..you may melt it again when you add the new lines.. Just depends on your skills. I've done it many times
kenmac is offline   Reply With Quote
Old 11-23-2010, 08:30 PM   #4
Rewards Points: 38
Thanks! I have done a fair bit of soldering. I plan to clean the new pipe, apply flux and insert into the bottom of the TEE while hot, then apply solder. I don't think I can easily clean the bottom of the Tee beforehand. Also, applying vise grips on the other 2 joints off the Tee may reduce chance of them loosening when I unsolder the bottom joint?
Old 11-23-2010, 08:43 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 904
Your tee is already to go. Do like you plan but don't put the vise grips on. Use a small hot flame and don't over heat. remove all the combustionables around the fittings so you don't have to worry about burning down the house. If the tees move some, reapply heat and reposition. Of course you want to make sure the water is removed from the pipes. A slow drip can make your job tough. Nothing worse then steam when your soldering.
Old 11-23-2010, 09:34 PM   #6
agreed, put something up around your plastic, you'll melt that in a heartbeat. You won't need to clean the bottom of your tee if you can keep the solder "wet" when you push in the new pipe. good luck and make sure you have NO water in that system.
immeraufdemhund is offline   Reply With Quote
Copper to Black Pipe Gas Connection dwolek HVAC 1 03-15-2010 05:02 PM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 08:32 AM
Soldering Copper chimney flashing buzzymalone Roofing/Siding 10 08-10-2009 08:28 AM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 12:08 PM
