Copper Pipe + Galvanized Valve - Bad??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2008, 10:20 AM   #1
Rewards Points: 18
Copper pipe + galvanized valve - Bad???
My home has all copper pipe but I noticed that the service valve to the laundry is galvanized. From the valve it's simply rubber hose to the washing machine.
Is this bad?? Will it corrode?? Should I replace it with a brass valve?? It's been this way for a long time.
davefr is offline   Reply With Quote
Old 04-23-2008, 11:39 AM   #2
47_47's Avatar
Rewards Points: 50
You should not have copper joined directly to galvanized. You will get corrosion. There should be a dielectric fitting between the two. I would replace the shut off with brass. As a side note, it is always a good idea to close the shut off valves when your washing machine is not in use.
47_47 is offline   Reply With Quote
Old 04-25-2008, 10:41 AM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
If its been this way for a long time don't worry about it. If you do not see corrosion now and its been that way for a long time why worry. I think it may have something to do with it being at the end of a line and no path to ground across the two dissimilar materials that is why you don't have corrosion. Just a guess.
Brik is offline   Reply With Quote
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 06:25 PM
repairing old galvanized pipe? darsunt Plumbing 2 04-08-2008 12:39 AM
electrolysis on copper pipe amakarevic Plumbing 5 03-24-2008 08:08 PM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 10:36 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
