Copper Pipe Corrosion? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2012, 10:01 PM   #16
Ravenworks's Avatar
Originally Posted by joecaption View Post
Wrong style shut off valve, installed up side down, I'd rip out all that old copper and replace with 3/4" pex, replace all the valves with ball valves. Replace all that wiring with romex run in PVC conduit.
No more rust ever.
Are you serious?
If you came to my house and told me to do that I would laugh at you.
The OP has a few minor problems,why make more?
All he needs to do at this point is properly fasten the piping.
Ravenworks is offline   Reply With Quote
Old 03-06-2012, 02:16 AM   #17
Thread killer
Rewards Points: 272
Originally Posted by Ravenworks View Post
Are you serious?
He's got galvanic action happening thats either going to turn the copper piping into a sprinkler head or rust a hole through the cable and all he has to do is fasten the pipe properly?
Canucker is offline   Reply With Quote
Old 03-06-2012, 09:16 AM   #18
Ravenworks's Avatar
Is it leaking now? Before OP tears his piping apart wouldn't you rather he correct the MINOR problems first then go from there? Yes he should start by securing the piping with the proper fastener(s) and yes he should separate other metals from the copper.
As for the corrosion looks can be deceiving,I have seen many cases where it was cleaned off with minimal effort with Scotch-Brite.
If it were mine there is no way it would be ripped out,at least not yet.
BTW,if I get time today I will do some before and after pictures of how easy it is to clean the funk off of copper to further inspect.
Old 03-06-2012, 09:37 AM   #19
Rewards Points: 29
I haven't closely inspected the pipe yet but I'll see about cleaning the corrosion off and looking for pitting. I need a plumber to install a shut off valve for the garden hose so maybe I'll have him take a look at the same time.
Peter D. is offline   Reply With Quote
Old 03-06-2012, 10:23 AM   #20
Ravenworks's Avatar
Peter,I honestly believe that it's not that bad yet,elbow grease is free and goes a long way to fix most problems.
Old 03-06-2012, 11:26 AM   #21
Rewards Points: 29
Yeah, I'll try cleaning it up first. It's really not in my budget to replace the entire pipe if I can help it. We've already spent a ton of money fixing a leaking roof in three spots, replacing leaky skylights, replacing blocked drainage pipes, replacing rotted wood around the house, etc... home ownership is so much fun!
Old 03-22-2012, 09:08 PM   #22
Rewards Points: 29
I made progress last weekend on securing the pipe. It's now attached to two hangers screwed into the ceiling. I admit my sheetrock skills are pretty amateurish! An electrician got the power cable hidden in the ceiling and installed a GFCI outlet near the pipe. I'll plug a heater cable in there and then put insulation over the pipe. Gotta plaster too.
Old 03-23-2012, 08:35 AM   #23
Ravenworks's Avatar
It looks like you are making progress and doing things the right way.
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 09:12 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
