Copper Pipe Corrosion? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2012, 08:19 PM   #1
Rewards Points: 29
Hi, this is my first time posting to this forum. I did a search but couldn't find the answer to my question, but first a little background.
My wife and I bought our first house 7 months ago and it has tons of problems... mice, drafts, sagging floors, rotted siding, woodpeckers, knotty pine paneling in the MBR, poltergeists... you name it.
Anyway, on to my plumbing problem.
At some point the previous owners had to dig a new well. A copper pipe comes through a hole drilled into the garage floor, up vertically between the garage doors, up to the ceiling and over to the water tank and filter system.
The problem I'm seeing under the foam insulation is that there's a metal braided power cable that is attached to the pipe with plastic ties. I guess it runs underground to the water pump. I'm seeing some corrosion on the pipe... green stuff basically. And they used metal fasteners to attach it to the ceiling and it's looking funky too.
I'm guessing I need to move the power cable off and tie it around the outside of the foam insulation.... but what about the 50 feet it travels underground? Is the pipe going to eventually start springing holes?
Peter D. is offline   Reply With Quote
Old 02-26-2012, 08:30 PM   #2
Rewards Points: 582
seeing is believing a picture would help....but if there are metal straps on copper ..get rid of them and use copper,plastic ones...
Old 02-26-2012, 08:38 PM   #3
Rewards Points: 29
I just snapped this with my phone. The small wires at the top are from the old garage door opener and aren't in contact with the pipe.
Old 02-26-2012, 08:43 PM   #4
Rewards Points: 582
see what you mean...get that junk off line...as far as metal strap under ground with pipe.....Iam from old school..if its not broke don't fix it... unless its easy to get too????
Old 02-26-2012, 08:46 PM   #5
Rewards Points: 29
It's buried under 4 feet of driveway! I'm going to have to hope for the best.
Old 02-26-2012, 08:47 PM   #6
Rewards Points: 582
yes I"ll hope with you best of luck
Old 02-26-2012, 09:10 PM   #7
Rewards Points: 29
I'm just trying to keep guys like you in business!
The Following User Says Thank You to Peter D. For This Useful Post:
ben's plumbing (02-26-2012)
Old 02-26-2012, 09:45 PM   #8
Water Treatment
Rewards Points: 902
Holes from the inside or outside?
What is the ph of the water?
Run the rest of what ever copper line that you can find and make sure that there are no Elect lines even phone lines around the copper.
Make sure that the house ground is not on the copper and that the well ground has been done correctly.
Akpsdvan is offline   Reply With Quote
Old 02-26-2012, 10:15 PM   #9
Rewards Points: 14,306
One of the many things you mentioned that would have been picked up by a good home inspection before buying.
Anytime there's any steel in contact with copper there's going to be corrosion. Those wires my run out to the well pump.
Where do you live. I hope it never freezes there or that garage is heated. If those old pipes freeze and burst your going to have a sprinkle system real quick.
Old 02-27-2012, 07:34 AM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
Copper reacts to different materials not just metal to metal contact, keep this in mind, could not see the ground clamp, buy the copper saddle clamp for electrical grounding point, this is important as a bad ground could cause problems in other areas. As to what you canít see get some quotes to replace and have it in the back of your mind so youíll have no surprises when and if it goes out , good luck with your new home.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-27-2012, 11:49 AM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 904
There plumbers/excavators who can pull a new line without disturbing your driveway. You may loose a little bit of slab at the entrance point. Worth making some calls.
Old 02-27-2012, 08:05 PM   #12
Rewards Points: 29
Here's where the pipe emerges through the garage floor directly underground. There's no basement.
Here's a close up of the pipe and power line as buried in a corrugated pipe. It looks like the powerline is wrapped in plastic pipe. I'm going to have an electrician look at it next week.
I'm going to check the inspection report for the water's ph.
ben's plumbing (02-27-2012)
Old 03-04-2012, 10:32 PM   #13
Rewards Points: 29
I carved out some free time today and made some progress fixing up this water pipe situation. I have no experience doing this work before. I'm just trying to save a few bucks but I don't want to cut corners.
Here's a few more before photos. The first is a shot of the pipe coming up through the floor between the garage doors.
Across the ceiling.
Here's where it takes a 90 degree turn to the water tank. Note that it's held up by a plastic strap connected to another water pipe!
There's a long span of pipe here held up by this copper strap. It attached diagonally to a floor joist above. The problem is there's no floor joists directly above.
The power line is now off the pipe and dangling in place until my friend the electrician takes a break from snow boarding. I also have a heater cable roughed in place. Once the electric work is done, I'm going to open the ceiling, add some 2x4's between the joists and secure the pipe with better hangers.
And here's some ugly corrosion! I'll find out if this needs to be replaced.
And on another subject, here's a shot of my son watching the 7th Voyage of Sinbad. Nothing beats the stop motion animation magic of Ray Harryhausen!
Old 03-04-2012, 11:36 PM   #14
Wrong style shut off valve, installed up side down, I'd rip out all that old copper and replace with 3/4" pex, replace all the valves with ball valves. Replace all that wiring with romex run in PVC conduit.
No more rust ever.
Old 03-05-2012, 08:29 PM   #15
Rewards Points: 29
Hmmm... great idea but it sounds pricey.
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 09:12 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
