Copper Pipe 101 - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 01:56 PM   #1
biggles's Avatar
Copper Pipe 101
good video if your new to plumbing with fittings and terms
Old 01-27-2012, 02:42 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 542
Nice find biggles
Old 01-27-2012, 04:43 PM   #3
biggles's Avatar
cool....especially when a threaded to swet is built up... always solder first before threading anything in...if you have to solder near an exsisting sealed threaded pipe the wrench in a bucket of ice works well...put the wrench on the pipe between the thread and the soldering joint heat sinks it right up... not over heating it,and let the solder work around the fitting
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Sweating copper pipe - what was I doing wrong Fortitude Plumbing 26 09-15-2010 09:12 PM
Connect 2" pvc drain to 2" copper pipe - no subfloor access missfixer General DIY Discussions 3 09-05-2009 05:44 PM
