Copper To Pex? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2014, 07:48 PM   #1
Rewards Points: 31
Planning stages for bathroom remodel. Currently have a 54" double vanity (circa 1968). Want to put in 2 single 24" vanities. Pictured is the supply lines under the current vanity.
I want to cut this garbage out and install t fitting on hot and cold pipe on other side of the wall (attic space on other side), then pex to the new faucets under their own vanities.
Is it a good idea to install shutoff valves for pex? Is pex suitable in this remodel?
Was going to do copper but came across is pex stuff.
Westbrook is offline   Reply With Quote
Old 01-12-2014, 07:54 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 550
pex is good but I don't see a picture?
Old 01-12-2014, 07:57 PM   #3
Rewards Points: 31
Ya pic up now couldn't do it via web on iPad.
Old 01-12-2014, 07:59 PM   #4
Rewards Points: 31
Also on other side of the wall the hot and cold supply lines bend 90 degrees down.
Old 01-12-2014, 08:06 PM   #5
Civil Engineer
Rewards Points: 4,686
Yes you need shutoff valves with PEX. There are all sorts of PEX specific shutoff valves, I like the quarter turn PEX ball valves, I picked some up from PEX Supply, but you can get them at most any plumbing supply store. You can transition from copper to PEX using a sweat on adapter, or a sharkbite I suppose, but I use all sweat adapters unless I need a disconnect, in which case a sharkbite is handy.
Daniel Holzman is online now   Reply With Quote
Tags
bathroom , copper , double vanity , pex , supply line
Transition from 3/4" rigid copper to 3/4 soft copper TVC15 Plumbing 2 10-05-2012 05:30 AM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 04:14 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 01:34 PM
