Copper To PEX - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 04:12 PM   #1
Copper to PEX
I'm considering replacing 4-5 runs of copper with PEX. The #1 and basically only reason is to get them into the ceiling and out of the way so I can create more ceiling space via a smaller soffit.
What brand PEX is 'best' and what type of clamping?
I'm in the beginning stages so likely will have more questions.
Thanks!
go_fire_69 is offline   Reply With Quote
Old 03-25-2013, 04:22 PM   #2
Rewards Points: 13,300
What ever brand your local supply carrys will work.
Any of the clamping systems work fine just find out what's avalible localy and pick that one.
In my area I can get the crimp rings in any hardware store, box store, plumbing supply so I went with them and never had any issues.
jaydevries (03-25-2013)
Old 03-25-2013, 04:44 PM   #3
Do I simply replace copper with the same size PEX?
Old 03-25-2013, 04:54 PM   #4
Depends, no one here knows what's there now.
The supply to the water heater and all main lines need to be at least 3/4' and use 1/2" supplys.
If you have some silly double shower heads or fancy shower systems then run 3/4 directly to the control valve.
Transition from 3/4" rigid copper to 3/4 soft copper TVC15 Plumbing 2 10-05-2012 06:30 AM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 05:14 PM
copper clad aluminum CopperClad Electrical 45 06-23-2012 04:21 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
