-   -   Copper to PEX (http://www.diychatroom.com/f7/copper-pex-175498/)
go_fire_69 03-25-2013 03:12 PM
Copper to PEX
I'm considering replacing 4-5 runs of copper with PEX. The #1 and basically only reason is to get them into the ceiling and out of the way so I can create more ceiling space via a smaller soffit.
What brand PEX is 'best' and what type of clamping?
I'm in the beginning stages so likely will have more questions.
Thanks!
joecaption 03-25-2013 03:22 PM
What ever brand your local supply carrys will work.
Any of the clamping systems work fine just find out what's avalible localy and pick that one.
In my area I can get the crimp rings in any hardware store, box store, plumbing supply so I went with them and never had any issues.
go_fire_69 03-25-2013 03:44 PM
Do I simply replace copper with the same size PEX?
joecaption 03-25-2013 03:54 PM
Depends, no one here knows what's there now.
The supply to the water heater and all main lines need to be at least 3/4' and use 1/2" supplys.
If you have some silly double shower heads or fancy shower systems then run 3/4 directly to the control valve.
