Copper Main And Iron Spigots - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2013, 01:09 PM   #1
Rewards Points: 278
copper main and iron spigots
The meter and main line coming in is 1" copper.
The interior plumbing are copper as well.
I noticed the 2 outside spigots in the side and backyard are iron with threads and a spigot is spun on.
I was wondering if this was common or where around the house did the plumbing changed to iron?.. home is in California 1990 slab foundation.
DIYGST is offline   Reply With Quote
Old 01-08-2013, 05:10 PM   #2
DIY staff
Rewards Points: 7,174
Most exterior spigots are cart brass with nickle plating--if they are Iron--electrolysis may occur which will corrode the connection--making replacement a bad experience.
Old 01-08-2013, 05:16 PM   #3
Rewards Points: 278
What I meant is that the pipe coming out of the stucco is iron.
happens to have some threads on the pipe with and a brass spigot on it..
have to put a magnet on the pipe to confirm but I don't believe it is possible to thread the a pipe that way if it is copper.
Old 01-08-2013, 05:22 PM   #4
DIY staff
Got you---they used a galvanized nipple to couple the copper to the spigot---you may be fine --but that would have been better if brass or copper was used----expect some trouble when the time comes to replace the spigot---the threads may be a bit corroded.
I do not suggest that you change it now---just be prepared for extra work if you ever find seepage or have a failure of the spigot---
DIYGST (01-08-2013)
Old 01-08-2013, 05:22 PM   #5
Roofmaster
Rewards Points: 2,172
You cant thread copper pipe. You can sweat a male or female copper or brass adapter to it though.
Old 01-08-2013, 05:33 PM   #6
Rewards Points: 278
Yes it appears so.. I am concerned how much galv. plumbing I have inside the walls?
Why isn't the copper plumbed all the way outside the stucco?
and should I be concerned about the builder threading the galvinized into the copper connection, which I assume a stub was soldered on and that should be a brass material. and copper-brass-iron is acceptable connection correct?
Old 01-08-2013, 05:43 PM   #7
DIY staff
The copper pipe has a threaded flange behind the wall---that is what is done by most plumbers--then,after the house siding is completed----a short threaded nipple is inserted through a hole in the siding --into the copper or brass threaded flange---the spigot is installed onto the exposed end of the nipple---
No sneaky business going on with the builder---no plumber is going to use threaded steel pipe unless it's a short nipple like that---threaded galvanized is to expensive and time consuming compared to copper or other modern materials.
It would have beed better,had they used a brass nipple or made up a copper one----but failure seldom happens in this situation---so I would not be concerned until there is a problem--then figure some extra time to install the new spigot---
DIYGST (01-08-2013)
Old 01-08-2013, 05:48 PM   #8
Rewards Points: 278
Thanks I understand now!
The Following User Says Thank You to DIYGST For This Useful Post:
oh'mike (01-08-2013)
Remove/Replace cast iron Y main drain and replace with ABS? graysqwrl Plumbing 5 06-17-2011 06:44 PM
Galvaized pipe to cast iron main. rosemonster Plumbing 0 01-04-2011 01:49 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 08:41 PM
Copper to Black Iron BigJimmy Plumbing 1 07-23-2007 09:43 PM
