That is why copper is used in some PT wood. That doesn't make it a suitable medium for treating domestic water. Domestic water is best supplied by pure sources and chemical treatments. Copper is primarily used in domestic water systems because of resistance to corrosion, strength and fire rating.
I suspect a different application for copper is being construed as also working for copper pipes.
A mixture of copper and 'other' materials are used in pressure treated wood.....i.e., Chromated Copper Arsenate (CCA-C), Alkaline Copper Quat (ACQ-C, ACQ-D, ACQ-D Carbonate), Micronized Copper Quat (MCQ), Copper Azole (CA-B & CA-C, μCA-C)....etc, etc.....the above 'mixtures' pertty much kill anything that goes into the wood.
As an FYI...wood rot is caused by little bugs....real little little bugs.....
Copper is an excellent material choice for home plumbing systems as it offers long-lasting high quality performance. Copper is also an intrinsically antimicrobial material. Mankind has taken advantage of copper’s antimicrobial benefits for thousands of years. Numerous studies have been published in peer-reviewed scientific journals proving this. Copper alloy touch surfaces are registered with the Environmental Protection Agency as materials that kill certain disease-causing bacteria. They can be used for handrails, door hardware, counter tops, and other touch surfaces where cross-contamination is a concern. However, the benefits are limited to touch surfaces. Antimicrobial claims cannot be made for copper tube in plumbing systems, there is no evidence that the water circulating inside the tube will be disinfected.
Anyone interested in learning more about this property of copper should visit AntimicrobialCopper.com.
Isn't copper also a choice to help keep mold/mildew off your shingles? Not too sure about bacteria but it certainly has some sort of growth-inhibiting properties.
Copper and copper alloys are bactericidal and fungicidal when used as vessels for storage and on dry surfaces.
Whether that applies to pipes that would normally transfer water at high flow, no, it doesn't..
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
