Copper Galvanized Pipe Corrosion - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2009, 10:30 PM   #1
Rewards Points: 260
Copper galvanized pipe corrosion
I need to pipe a hot water recirculation system for my hot water heater. I need to T into the drain spigot on the bottom. I will use a short galvanized nipple, galvanized T, then a spigot. The other side of the T will be copper. How can I keep this from corroding? It already has this system installed and has very bad corrosion. Do they sell 1/2 copper nipples, T's, etc.? I could also go with a dielectric union at the top of the T and at the spigot. What are my options here?
bluefitness is offline   Reply With Quote
Old 07-09-2009, 10:32 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Please use brass T's and nipples
Old 07-10-2009, 10:02 AM   #3
BIGRED
Rewards Points: 252
What Plumber 101 said. Steel and copper do not mix. Bronze is nonreactive with copper and will not cause the the threads in your tank to corrode either.
Grampa Bud is offline   Reply With Quote
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
Allen screw and copper pipe? dolvio Plumbing 1 02-09-2009 06:38 PM
Copper pipe + galvanized valve - Bad??? davefr Plumbing 2 04-25-2008 10:41 AM
repairing old galvanized pipe? darsunt Plumbing 2 04-08-2008 12:39 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
